SOURCE: upside down images
ALL telescopes will show the image upside-down. You learn to adjust for this. IF you must, they do make a lens called an "erecting lens" that would flip the image back right-side up.
Posted on Dec 28, 2008
SOURCE: upside down images on my telescope. Bought used -no manuel. What to do?
In a refractor images are upside down as with most telescopes. You need an image erector to create a normal correct R and L and Up and Down image. It is a lens which goes in front of the eyepiece to give a correct image.
Posted on Jun 02, 2009
SOURCE: everything is upside down
Astronomical telescopes produce an upside-down and reversed image (image is rotated 180 degrees from an upright position) since this doesn't matter when you are looking at things in the night sky. Accessories are available for rotating the image to an upright position, but most of those accessories do not work well with Newtonian style reflector telescopes such as the 114EQ reflector.
Posted on Jun 26, 2009
SOURCE: Just came into a used tasco 302048 . Everything is upside down!!!
the scope is made for both terrestrial viewing and astronomical. In order to see terrestrially upright, you need an inverting STAR DIAGONAL. The eyepiece will do nothing for inverting the image. you might have 2 diagonals in the kit that came wih the scope. the diagonal is the part that fits into the scope. then you place the eyepiece in the diagonal. if you have 2 diagonals , one is a 90 degree angle,(astronomical) and one is a 45 degree angle, (terrestrial). the eyepieces change the magnification of the image. the bigger the number (9mm, 20mm, 26mm,) the smaller the image. the smaller the number , the bigger the image gets. the number is inverse of the image. Hope this helps.
Posted on Oct 23, 2009
SOURCE: my 102mm astro-nova telescope shows everthing
No, all astronomical telescopes show upside down images. You can buy what is called an "erecting prism" (just Google it) to use for terrestrial viewing.
Remember --- no up or down in space! Read my "TIPS" in my Profile, called ----"Frequently Asked Question".
Clear Skies!
Posted on Dec 29, 2009
Testimonial: "Thanks for the help!!"
Jan 02, 2015 | Optics
Dec 29, 2014 | Celestron AstroMaster LT 76AZ Newtonian...
Jun 11, 2014 | Celestron PowerSeeker 114 EQ Telescope
Feb 28, 2013 | Vivitar Viv-tel-76700 75x/350x Reflector...
Dec 26, 2012 | Optics
Aug 03, 2010 | Fieldvision 114mm Reflector (114 x 114mm)...
Oct 15, 2009 | Bushnell Voyager 78-9970 Telescope
Sep 01, 2009 | National Geographic 76AZ (525 x 76mm)...
Jul 20, 2009 | Meade DS-2114 ATS (325 x 114mm) Telescope
Jun 01, 2009 | Fieldvision 114mm Reflector (114 x 114mm)...
451 people viewed this question
