Question about Casio Watches
Casio pro trek volume barely audible - Casio Watches
Posted by steven mcneill on
Tom Chichester
    Top Expert:
  • Casio Master
  • 55,379 Answers
If the battery is known to be good, the watch may be defective.
Posted on Nov 24, 2018
Testimonial: "thanks, battery good"
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: Casio pro-trek PRG-60T Buttons no longer activate anything.
Is the battery indicator on L (Low). If so only timekeeping will work. Check out the manual which tells you that.
Try sticking the watch in a window to charge it till the battery indicator gets to H (may take up to 10 days for a very run down battery). If that doesn't work it send it to Casio for a battery change. Cost of change just over 20GBP sterling.
Posted on Feb 19, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: reset casio pro trek prg 80l after discharge of
You can find details here: http://world.casio.com/wat/download/en/manual/
Rate me, plz.
Posted on Jan 10, 2010
Anonymous
SOURCE: casio PRO TREK error 'OP EN'
The problems is very simple: On the back cover (inside) is a little Cu metal Part. This part is glued to back cover using a poor glue (rubbered glue) and, in time, is moving from original position. You must put back this parts to original positin ( a little hole inside of back cover) and glue using a good glue. When the back cover is mounted , this part must have a ferm contact with two springs from mechanism (sensor for back cover open). If beatwin this springs isn't a electric short (using Cu metal parts) the internal mechanism of watch "see" the back cover is open and show "OPEN" on screen!
Posted on Apr 02, 2010
Testimonial: "Simple .... once you know ! (as most things) The "obvious" question is: How did you figure it out ? But THANKS !!"
David Tolond
  • 2501 Answers
SOURCE: just got my husband a
As a pure shot in the dark, are you sure that you calibrated it so that it was pointing to the north when it should be and not to south?
If it was pointing south instead of north, then East and West would be reversed.
Sounds a bit daft but better than the directions of east and west changing?
Check your calibration perhaps?
Posted on Nov 29, 2010
kerguney
Kazim ERGUNEY
  • 577 Answers
SOURCE: Change time on a pro trek casio
you need to look at the user manual that
you can download a soft version of the user manual on below link. .when you open the link just write the 4 digits code on the back side and click searched on the URL below
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Posted on Oct 09, 2011
How to set auto day light savings time on casio pro trek
Try Googling (casio)(model)(manual) without parens.
Nov 05, 2017 | Casio Watches
Pro trek 3500 compass only going up 300 degrees. Doesn't reach 360 north???
THe PRO-TREK watch compass is very sensitive to nearby Iron (eg. cars, fridges, steamships, artillary canons, battering rams, guillotines, etc) and anything wearable or embedded in your body. I had to calibrate mine in the middle of a baseball field.
Aug 09, 2017 | Casio Digital Compass Twin Sensor Sport...
How do I set the alarm on a men's Casio Pro Trek digital atomic watch pq635?
Get in touch with Casio support: http://www.casio.com/support
May 08, 2015 | Casio Watches
My pro trek solar powered watch still tells the time but other functions dont work any idea
CASIO has so many complicated watches and they all have different uses, etc. Your BEST bet is to check out their awesome website. They have a FAQ area where I would check, or just ask their customer service. Sorry. Best I can tell you. Best regards.
http://www.casio-intl.com/support/
Aug 23, 2010 | Watches
Casio PRO TREK error 'OP EN' Display frozen with the above msg. None of the buttons - except the light - works. Whats wrong .. battery charge shows FULL
Mar 22, 2010 | Casio Watches
I have a casio watch what has a moon and tide phase graoh but no instructions
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please
Mar 08, 2010 | Casio Pro Trek Tide Moon Graph Titanium...
Send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2.
Feb 19, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
Watches Logo
107 people viewed this question
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Robert
Are you a Casio Watch Expert? Answer questions, earn points and help others
