Televison & Video Logo
Question about Alba Televison & Video
How to eject a DVD from an Alba TV model LCD22ADVD
Posted by Stephanie Kilgallon on
1 Related Answer
Anonymous
  • 14553 Answers
SOURCE: Alba model LCD22ADVD not recognising DVD's. Message
Either a dirty or a bad optical pickup unit in the player---if bad it will have to be replaced and usually cheaper to buy a new set.
Posted on May 22, 2012
How do I eject disc from 19” Alba tv/dvd with one for all remote
Your One for All remote control may not have a DVD ejection function.
Lcd22advd switching to AV2 selection as far as i can tell it does not have a option to switch the only options it does have is tv,dtv/usb,dvd,ext,fav,hdmi,ypbpr,pc/vga also there is no button on the...
ok i bit confused to your problem, is it switching on it's own and is it always to AV2, or is it when you use the remote it switches over??
they should be a source button on the remote which allows to switch between connection modes. best regards
My alba lcd22advd keeps flickering while on fav channel
check for a dry joints at the inverter board for the screen back light, which may have loose contact.
1helpful
I have an alba 16inch LCD TV/DVD combi. I played a DVD but can't eject it. How do I get it out?
You will have to remove the back cover of the TV and push the DVD out. Do not do this with the power connected.
I have a 5 month old Alba DVD Tv combo model number LCD22ADVD. The DVD has stopped working and when DVD input selected, instead of showing the usual DVD home screen, it now shows a bright blue screen. The...
Sometimes a dvd can be ejected manually but mostly the unit must be partially dismantled but if you try to do that you will invalidate the warranty - at only 5 months old it will be the responsibility of the supplier/retailer to cure the problem. I suggest you re-read the instructions and then contact the supplier without delay.
Then you should contact the dvd rental company and tell them what is happening.
2helpful
Lcd22advd need unlocking code
9,7,3,5 in DVD mode then press 0. Worked for me!
8helpful
2answers
TV Tuning on ALBA TV with DVD player
you start with tv,dvd mode to your remote control when you have alread make sure your in tuner you hit menu mode and show you the instruction select arrow shows _ + try it.
Top Alba Televison & Video Experts
 Grubhead
Grubhead
NOEL
NOEL
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
