Question about Mitsubishi Heating & Cooling
14 flashes is a fault code. You need to determine which light is flashing and look at an online Mitsubishi fault code analysis chart for your model. The light(s) that flash determine the fault. Power, defrost, timer light flash all mean something different.
Posted on Nov 25, 2018
SOURCE: no heating from Mr slim
P8 refers to outdoor protection device activation usually caused by low gas charge or blocked condenser coil. any good a/c company can resolve this for you. however please note that if it is gas related a pressure test must be carried out to determine where that potential leak may be and that can be very costly.
regards
Ed
Posted on Nov 14, 2007
SOURCE: Mitsubishi Mr. Slim M/N MSH15EN
Try calling G A Larson's for technical advice. I think that they handle this product. 499-0866
Posted on May 22, 2008
SOURCE: Mitsubishi Mr. Slim Mini Split MS-A12WA Indoor Unit
no sir gary,
the water would not go to the drain pan if you install it vertically.
water would just drop anywhere and would ruin a lot of things...
tnx 4 using fixya,
drcool
Posted on Sep 13, 2008
SOURCE: Mitsubishi Mr Slim air conditioner
get model and serial #s and look up unit for diagnostic codes
Posted on Nov 26, 2008
SOURCE: Replacement compressor for Mitsubishi Mr. Slim Air Conditioner
pls no overhauling repair no spare part avaliable for hermetic comp[ressor the right is to change it
Posted on May 02, 2009
Feb 05, 2016 | Mitsubishi Electric Mr Slim E12C26426...
Feb 14, 2015 | Mitsubishi Electric Mr Slim E12C26426...
Oct 18, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
May 26, 2012 | Mitsubishi Mr. Slim MXZ30TN Air...
Aug 28, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Jun 02, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Feb 05, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Feb 16, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Oct 04, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Aug 27, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
921 people viewed this question
