SOURCE: how connect subwoofer to onkyo 8522
does it have speaker wire in and out use then from fronts
SOURCE: sub output
With RCA cables. Just plug into the preamp outputs on the back that are labeled for "subwoofer" and run them to your amp. In your on-screen EQ, you'll have a separate adjustment for the sub (which adjusts that set of preouts, without affecting the tone in the rest of the speakers).
SOURCE: set up m-audio buddy dual mic preamp
ive got a problem cuz this thing doesnt have a ******* firewire port. and i was hopoing to use this for pro tools. i need to know where i can get an adapter of some sorts. but what you should do is hook the mics in to the back ports. adjust volume. then do the ****
SOURCE: car speakers pop when on/off new stereo preamp out to Bose amp
Hi mate
this maybe caused by a positive and negitive wire touching somewere down the line!
just follow up your wires and check
SOURCE: car stereo pre-out signal noise
Two things, a ground loop isolator in-line with the RCA's between the head unit and the first amp.....also a noise reducing capacitor ( $5 or$6 at an auto parts store) on the alternator 12v post will reduce or remove the hum.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Those pre out is for sub connection
