Radio Communications Logo
Question about Radio Communications
I bought two sets of the BAOFENG BF-888S radios. How do I get all four to work together?
Posted by David graves on
My Baofeng 888S doesnt squelch
What is the green flashing light on my baofeng 888s
It means it is receiving a signal. It is good to read the manual when you first get it, and then again after you have used it a few dozen times.
BaoFeng BF-888S
https://baofengtech.com > BF888s_Manual
PDF BaoFeng BF-888S ... Lights red during transmit, green when receiving a signal ... you that battery needs recharging. Alert tone will sound and Red LED will blink.
7 pages
1helpful
3answers
How can I get my Motorola CLS1110 to talk to my Baofeng BF 888s?
The CLS has preprogrammed frequencies. The Bao can be user programmed. If both are Uhf, the Bao must match the CLS unless one of the CLS frequencies is already in use in the Bao. So, are you already using CLS and adding radios? You need the actual frequency and tone code. If you do not understand, contact a dealer like us, local is even better! Channel 1 is only an indicator, not a frequency. [email protected]
2answers
I need to tune my baofeng gt-3 mk2 to the same frequency as my baofeng bf-888s I can hear the bf-888s with my gt-3 but cannot talk I've tried every website why cant i talk over it????
1. Make sure both radios are transmitting and receiving on the same frequency (no repeater offset).
2. Either turn off CTCSS tone or make sure both radios are set to the same tone on both Tx and Rx.
2answers
I can't upload the presets for bf-888s even with the software disk provided. Need datiled instruction.
The usual problem is an incorrect driver for the usb/serial chip in the connecting cable. Windows installs the latest driver but clone chips need an older version. There's good advice on these pages:
USB Cables and Drivers for Microsoft XP, Vista, W7 & W8
http://www.miklor.com/COM/UV_Drivers.php
Baofeng BF-888S
http://www.miklor.com/BF888
I have purchased three Baofeng radios ,but loose communication or contact after 1km,what can I do in order to increase frequency?
Frequency is not the issue. Power is. Also check to be sure you haven't set the squelch controls to too high a level which would reduce the range.
2helpful
2answers
I just purchased two Baofeng BF 888s radios and had them programmed to our frequency here. They will both receive and transmit with each other but not transmit to the radios we already had. Any ideas?
Your radios could be programmed with subaudible tones (CTCSS) or digital code squelch (DCS) which the new radios do not have. They can be programmed for it, you need to find out what tone/code you are using.
It could also be that your existing radios are programmed for a "duplex" repeater channel, with different transmit and receive frequencies. The new radios might be on the "repeater output" frequency so they would not activate the repeater.
Both could be the case, missing tone and duplex frequencies.
I would check the programming of the new and old radios, especially for tone/code squelch.
Top Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
