Question about Amana Dryers
I have a Amana Dryer that's 2yrs old and it stopped working and I was wondering where the reset button is located at?
Posted by Emily Jones on
Chris Huff
    Top Expert:
  • Amana Master
  • 6,289 Answers
Probably not one. Many different possibilities. Explain “stopped working”. As in no heat, won’t run, etc
Posted on Nov 23, 2018
5 Related Answers
elhomspam
Raymond Cardona
  • 58 Answers
SOURCE: Whirlpool Duet Dryer (2yrs old)
Sometimes when a bulb goes out or is replaced the unit can short out.
Try holding your end of cycle signal button for 5 seconds, watch the light, if you control lock it, it will light but will not run because control lock is a safety feature.
Also try pushing door in and starting it, might be bad latch
Posted on May 02, 2008
Anonymous
SOURCE: Amana electric dryer model LEA30Aw will not heat
The heating element measures 10 Ohms at 68 degrees farenheit. Usually if the element is bad, it will measure infinity.
Posted on Dec 29, 2008
Anonymous
  • 142 Answers
SOURCE: Amana PTAC PTC093A35AA won't blow heat
The reset button is located behing a panel on the front of the unit that is labeled Heat Reset. If that label is gone then look around, it is a small hole, small enough for a paper clip to fit through.
That being said, I have 137 of these units in one of my hotels and have not had a single one needing to be reset. You probably are going to need a new control board kit. These can be purchased from Amana. They are $130. Make sure that you have pulled the heater coil out and inspected it first. Also, there was a recall years ago where Amana was supposed to contact and send out new voltage switches. These are the round black things that the Brown heater wires connect to on the upper and lower side of the heating coil. You should also try to replace those if you find the coil in good condition. I have had those resolve heating issues. Most of the heating issues were a result of a bad relay on the control board though.
Please remember to rate this fix.
Posted on Feb 12, 2009
ImJustAvg
  • 2006 Answers
SOURCE: Amana dryer model YNED7200TW will not start. there
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Posted on Jun 08, 2011
oldTech2332
Gene Meier
  • 2341 Answers
SOURCE: AMANA DRYER MOD # P
To open that dryer ya need to first remove the top by removing the screws in the rear of it,then remove the control panel...behind the control panel are screws that hold the front panel to the cabinet.
this tip i wrote will help ya to determine why its not heating...after disconnecting the front panel it can be letf connected to run the dryer to see whats happening as far as the igniter not coming on or whatnot
Here is that tip http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Posted on Sep 10, 2011
Is it worth getting my Beko tumble dryer fixed?
of course only 2 years old it should be .
Mar 12, 2015 | Dryers
Stop button doesn't work on Amana NED7200TW Electric Dryer.
Check the door switch to see if it "clicks" when you push and release it. If it clicks, then the control board will need to be replaced. Here is the part you will need to order.
Nov 01, 2012 | Dryers
Amana distinction dryer reset
No. The timer position determines when the dryer runs and stops.
May 30, 2012 | Amana ALG443RAW Gas Dryer
AMANA DRYER MOD # P NGD 7200TW FRONT LOAD ABOUT 1 1/2 - 2YRS OLD NOT GETTING HOT WHEN TURNED ON HOW DO I OPEN FRONT PANEL TO CHECK IGNITOR AND SENSORS
GENE
Sep 10, 2011 | Amana ALG230RAW Gas Dryer
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
$10.70
More
In Stock
Jun 08, 2011 | Amana Dryers
TS error unresolved on ned7200tw
I have a gas model but this is what I found on the sight and it helped :
dt63 2 Solutions February 27, 2010
Check to see if your thermistor is bad by measure the resistance. It should be 10K Ohms at room temperature.
If it's bad, replace it BUT you have to CLEAR to error code.
1. Enter to Service Mode by press CHIME and TEMPERATURE keys for 3 seconds or until 3 beeps are heard.
2. Access Diagnostic Codes by pressing WRINKLE PREVENT. A d will be displayed. Rotate the CYCLE SELECTOR KNOB in either direction to read it.
3. Press SENSOR DRY and TIME keys for 3 seconds to clear it.
4. Power OFF to exit Service Mode
5. Power ON
Jul 12, 2010 | Amana NED7200TW Electric Dryer
Dryer won't run. Stops after 30secs
Sounds like the timer is going bad and it needs to be replaced. The time is located behind the knobs.
IF my answer has satisfied you please rate. Thank you
Feb 11, 2009 | Amana ALG331RAW Gas Dryer
Dec 24, 2008 | Amana Dryers
Diswasher won't start
Try holding the reset button in for about ten seconds.
Nov 26, 2007 | KitchenAid 24 in. KUDP01IL - Multiple...
Dryers Logo
57 people viewed this question
Top Amana Dryers Experts
Marvin
Marvin
jdthefixer
Are you an Amana Dryer Expert? Answer questions, earn points and help others
