Question about Rival Kitchen Appliances - Others
Our roaster is not making any heat. It's a programmable 20 quart Rival roaster. We don't have the manual to know if we're doing something wrong
Posted by Carla Holste on
Steve Pack
  • Rival Master
  • 4,340 Answers
1. Place the REMOVABLE ROASTING PAN into the ROASTER OVEN BODY.
2. Make sure that the TEMPERATURE CONTROL is in the OFF position, then plug cord into a 120 volt AC outlet.
3. Turn the roaster on by turning the TEMPERATURE CONTROL to the desired temperature.
4.Preheat for 15 to 20 minutes. (INDICATOR LIGHT will shut off when temperature is reached)
5. Place ROASTING RACK into the REMOVABLE ROASTING PAN, put food on the RACK, and place the LID on the roaster oven.
NOTE: Some foods or recipes do not require the ROASTING RACK to be used.
6. When finished, turn the TEMPERATURE CONTROL to the OFF position and unplug roaster oven from outlet.
7. Remove
if it plugged and plugged to roaster and it still does not work move a known working plug. still does not work, there is no repair.
Posted on Nov 22, 2018
5 Related Answers
Anonymous
SOURCE: Need a manual or recipes for roaster
I have an Owner's Guide for a Rival 22 qt. Roaster Oven, model# RO230-C saved as a PDF file if you want it.
Posted on Nov 26, 2008
Anonymous
SOURCE: can't find the owner's manual for my rival 16 quart roaster oven
http://www.rivalproducts.com/help.aspx?helpNav=1
This link has a chart for cooking/roasting time on Rival Roaster
Posted on Dec 17, 2008
Anonymous
SOURCE: Rival RO200 BC 20 Quart Programmable Roaster Oven
I dropped mine on the floor and had to replace my handle and lid. They have all of the parts you might need. I located the 1-800 number on their website: www.rival.com
1-800-323-9519
Posted on Feb 04, 2009
Anonymous
SOURCE: Lost my instruction manual for my Rival oval roaster
Need a manual for an olive green Rival crock pot, serial number 517 control number 3350610, very old, HELP SPC
Posted on May 06, 2009
Jason Stephenitch
  • 254 Answers
SOURCE: Seeking Manual for Rival SS 18 qt Roaster Oven
Follow this link and you'll be able to view your roaster's manual in PDF format.
http://www.rivalproducts.com/manuals/MANUALS/RO180BR-C_43_18972586.PDF
I hope this helps and Happy Thanksgiving! :)
Posted on Nov 13, 2009
My 20 quart seems like it don't heat right
dated: Wednesday, November 20th, 2013
Call:
Rival Customer Service at 1-800-557-4825
Nov 14, 2013 | Rival 18 Qt Roaster Oven with Buffet...
I need a replacement handle for a Rival 20-quart roaster. Any idea where to find one?
No solution here but I have the same issue with an 18 quart roaster. Called Rival and they don't have handles and they didn't have any suggestions!!
However I did measure out the distance between the holes and it is 6 1/2 inches apart. Hopefully either an appliance retail/repair store may have something or even a hardware store. That's where I'm going!
Oct 16, 2010 | Rival Kitchen Appliances - Others
How to roast a turkey in 18-quart Rival Roaster Oven. Need full instructions for 14 pound turkey. Have lost manual!
Hello Carolyn,
Here's a link to the Rival web site and your instruction manual for the 18 quart Rival Roaster. Basically you set the roaster to 350 (fresh) or 375 (pre-basted frozen and thawed) degrees and cook the Turkey for 9-14 minutes per pound of the turkey. Use a meat thermometer and cook until the Turkey reaches 180 degrees.
I would download and print out a copy of the manual for your use and reference. I also save an electronic copy of all the instructions and owner's manuals on my computer in a file I've titled "Household Items - Manuals & Guides". This makes it easy to retrieve them in the case I lose them again, as they might not always be available on the internet forever.
I hope you find this Very Helpful and best regards!
Dec 24, 2009 | Rival 18 Qt Roaster Oven with Buffet...
No manual
The manual is available on line here:
http://www.rivalproducts.com/manuals/MANUALS/RO188BR_43_81844057.PDF
The roaster works well as a giant slow cooker (200 low, 300 high) and you can use almost any oven recipe, including baking. DO preheat 20 minutes, and do keep the lid on.
Nov 26, 2009 | Rival 18 Qt Roaster Oven with Buffet...
Manual for rival® 18 quart ss roaster w/buffet
Try Googling " user manual for rival #174 18qt ss roaster" You may need to go to the Rival web site and request user manual. Also, you may need the serrial #.
Jul 26, 2009 | Rival 18 Qt Roaster Oven with Buffet...
Need instruction material for Rival turkey roaster
Hi JJ, the instructions are here, just click on the link:
Accu-Roast 20 Quart Programmable Roaster Oven Owner’s Guide
By clicking on the link it will open a pdf document.
Let me know if it opens.
Afterward you have to print it if you want it on paper.
Nov 06, 2008 | Crock Pots & Slow Cookers
1-800-323-9519
Oct 25, 2008 | Rival 37601 6-Quart
Broken handle on crockpot
The handle on my rival 20 quart programmable roaster oven is broken. Where can I get a new handle?
Aug 09, 2008 | Rival 37601 6-Quart
Kitchen Appliances - Others Logo
133 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Michael Thomas
Michael Thomas
Paul Carew
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
