Question about EA - Electronic Arts The Simpsons Game
How do i defeat the dragon ? at the start of the level and weres the ash tray
Posted by manday_1 on
super_guy
  • 1,986 Answers
Patty and Selma make up the heads of a two headed dragon (real surprise there)
that is reeking havoc on a village. First recruit some villagers with Marge's
mob control. Now switch to Homerball and watch the dragon. It flies and pauses
in between gaps in the bridges that make up part of the upper area. Blast across
the bridge and into the dragon to knock it to the ground. Now switch to Marge
and command the minions to attack. Repeat three times to defeat the dragon
before it destroys too many homes.
The next area is a dungeon. The Moe's will continue to attack until you destroy
the gray brick structure they are spawning from. The coffins house more
potential mob members. Continue forward and grab Marge's police hat near the
bridge. Go up the stairs to the left destroying Moe's and enemy spawn doors.
At the top is a treasure chest and a lever that opens the large door below.
Pass through the door and fight of Otto and his spawn point. Step on the buttons
to enter the overhead camera dungeon crawler portion of the game.
Move up to the large closed off area with the Moes and destroy the wall. Defeat
the Moes and grab the key. Move back around to the yellow wall and it will
disappear. Enter the hole in front of the statue. At the next part of the
dungeon turn left and go to the end of the hall. At the dead end is another
giant key. Head back down and move to the right of the screen toward the
Moes behind a wall. Destroy the wall and retrieve another key. Now move all the
way to the bottom of the area and open the last gold wall to find the exit.
Destruction of both spawn points reveals a couple of pressure plates that opens
the door. Inside are several spawn points and numerous enemies. Try to take out
of the spawn points at first. Once the enemies are gone command 4 mob members
to stand on in each of the claws of the giant dragon. This raises stairs of
gold. Take the stairs on up to the dragon's eyes. Send Maggie inside the right
eye. Press two red buttons to open the dragon's mouth. Enter the mouth and
face three phases against the dragon sisters.
During each phase of the boss fight Homer has to float up and bop Patty and
Selma on the head. Just watch the flight patterns and hover in the area where
it flys the most. In between the 2nd and 3rd wave is an egg wave. Have Homer
run through the eggs to destroy them. If any egg remains it turns into a Moe.
Posted on Aug 19, 2009
How to replace 95' chevy sub ashtray spring
First thing we need to do before anything is to remove the little feet that the ash tray sits on when it is open, and bend their tabs out of the way so we can open the ash tray to its fullest open position.
To do this, you'll need to play contorsionist a bit, and pull out the little rubber pads from behind the ash tray, then carefully bend the tabs back into the side wall of the ash tray assembly. You can refer to my pic below to see which tab I mean -- And you can also see the remains of the rubber foot in the background .
Once both of these tabs have been bent out of the way, you can then take the ash tray door, and pull it down towards the floor as much as you can.
Doing this will expose a small pin head sized hole in the side of the ash tray, and also a rounded triangle in the sides of the assembly housing, with a small notch at the top. The springs sit inside of these four holes / notches.
Ok, so now that you've got your springs ready to go, its time to install them. You want to take the end of the spring that has a little bit of a bend to it, and slide it into the hole. This will keep the spring from falling out in a few seconds. Once you've got the springs into the side of the ash tray, you'll want to take a skinny screwdriver, and use it to push the spring up and behind the ash tray where you can grab it with your finger.
Then both slightly close, and move the spring into it's proper slot at the top of the triangle. Repeat for the other side, and close the ash tray. It should hold itself shut, if not, make sure that you've got the coils of the springs oriented towards the firewall.
After you've got that finished, then bend the little tabs for the pads back to where they were, and re-install the little pads. You're good to go!
We Are Here To Help !!!
__________________
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Sep 02, 2014 | 1995-1997 Chevy Suburban Ignition Starter...
Replace old ash trays with new ones on rear door panels
Any salvage yard should have a few cars to get them out of, they usually are like new.
Jun 02, 2012 | 1999 Lincoln Town Car
Wannn'a know the cheats
there actually isn't a helicopter cheat. Only Vice City Stories has drivable helicopters.
Apr 19, 2010 | Sony PlayStation Portable (PSP) Console
Replace light bulb under dash that shines on console and ash tray
remove the ash tray,then remove the screws that hold
the ash tray bracket in place the bulb will be very easy to change then.
Jan 07, 2010 | 2001 Dodge Dakota
How to defeat malfore
Okay so you are going to fight him three times. My first suggestion is to get unlimted life which is really easy. While playing hold down the L1 button and press: right, right, down, down, left. This will give you a little advantage but not much. You should also make certain that Spyro has on the Dark armor as this is the only thing that will really do damage. Once you start fighting, fly close to Malfore and use Cynder's fury breath. this is done with the directional pad, pressing any direction twice. Second fight, do the same but be sure to dodge the ice. Third fight: Repeat until dead.
Hope the cheats help. Let me know.
Apr 26, 2009 | Sierra Entertainment The Legend of Spyro:...
Mythos of marge - nintendo ds - the simpsons games
Mythos Of Marge: Easy completion An easy way to finish the Mythos of Marge level is to stand in the ash tray and wait for the dragon to return there. Punch it while it is inside the ash tray. You will not be harmed by the fire because there is an invisible shield in the ash tray.
info got from http://www.chaptercheats.com/cheats/ds/23996.htm
and go here to a forum where people discuss the actual level and how to play through it http://www.gamefaqs.com/boards/genmessage.php?board=939420&topic=41215448
I hope this helps
Jan 02, 2009 | EA - Electronic Arts The Simpsons Game for...
Cheats for DRAGGONBALL Z BUDOKAI TENKAICHI 3
the only cheats for this game, are unlockable Charactors.
Android 8 - Defeat "Affectionate Android"
Arale - Defeat "Dream Match: Goku vs. Arale"
Babidi - Defeat "Farewell to the Proud Warrior"
Cyborg Tao - Defeat the second level of the Otherworld Tournament
Devilman - Defeat "Unexpected Help"
Dr. Wheelo - Defeat "Strongest in the World"
Fasha - Defeat the third level of the Yamcha Game
General Blue - Defeat "Penguin Village"
Goku GT - Defeat "Immortal Monster"
King Cold - Defeat the third level of the Cell Game
King Piccolo - Defeat "Goku Strikes Back"
King Vegeta - Defeat "Galaxy Battle"
Nail - Defeat "Super Saiyan"
Nam - Defeat "Ceiling vs. Ground"
Nuova Shenron - Defeat "Solar Warrior"
Pilaf Machine - Defeat the second level of the World Martial Arts Tournament
Spopovich - Defeat the third level of the World Tournament
Tambourine - Defeat "Goku Strikes Back"
Hope This helps Mike @ Compurepair.
Feb 23, 2008 | Nintendo Wii Console
EA - Electronic Arts The Simpsons Game Logo
882 people viewed this question
Top EA - Electronic Arts Video Game Consoles & Games Experts
Barbat Nae
Barbat Nae
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
