Question about Onkyo Audio Players & Recorders
Contacts for Onkyo service in Cape Town in this link.
https://www.google.com/search?q=cape+town+onkyo+service+centre
Posted on Apr 24, 2021
Since we are in the usa we would not have information about stuff in cape town sa
SOURCE: Onkyo RC-649M remote
Remove any screws you can see and pry the case open. you will see a rubber pad and a circuit board. Clean both with alcohol and dry. reassemble and it should be OK
Posted on Jan 23, 2009
SOURCE: Remote control via RI terminal on Onkyo Receiver
Not sure I can solve, but maybe help. I am having a similiar problem. However, make sure you Analog Audio (RCA type) cable are connected even if using Digital connection between the two. They use those cable to send the Commands (Mentioned in the documentation).
If you did get yours to work, please give me a hint... I upgraded mine from a 603 to a 701 and haven't been able to get it to work since.
Posted on Feb 14, 2009
SOURCE: remote code for sony playstation 3
you cannot control a ps3 with that remote because the playstation 3 only works with bluetooth. I'm sorry to have to tell you. you can purchase a remote that works with your system at any that sells your system.
hope this helped
please rate well.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Posted on Mar 06, 2009
SOURCE: Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
time warner does not supply the codes. the equipment manufacturer supplies the code to the remote makers
Posted on Jun 04, 2009
