Question about GPS
I have no sound on my Kodak 265 ektasound projector
Posted by Harry Stanley on
1 Related Answer
Jim Auburn
  • 412 Answers
SOURCE: manual for kodak ektasound moviedeck projector 275
Check with www.micro-tools.com for parts and manuals!! They have an amazing inventory of classic Kodak parts for slide & movie projectors! Good Luck !! Jim
Posted on Jun 25, 2012
My Kodak Carousel 750H slide projector will not forward next slide or reverse
Your projector problem sounds like a broken cycle solenoid LINK. The LINK will be available from: www.micro-tools.com
They should have installation instructions, as well. See the attached picture for more details. Good Luck!! Jim
Dec 09, 2013 | Kodak Office Equipment & Supplies
Kodak carousel makes a buzzing sound and will not advance
Your problem is most likely related to cycle contact adjustment. See the attached illustration for the parts involved and the SPECIFIC POSITION of the contact parts:
Sep 08, 2012 | Kodak Carousel 4400 Slide Projector
Manual for kodak ektasound moviedeck projector 275
Jun 05, 2012 | Kodak Vintage Ektasound Moveideck 265...
Kodak 16mm projector
See my other response! Check with the George Eastman House in Rochester, NY for leads on the manuals! Good Luck !! Jim
Nov 19, 2011 | Office Equipment & Supplies
I have a kodak 5600 slide projector. Everything was working great and when I changed the carousel the slides wouldn't fall to be viewed or would fall half way. This projector is almost new even tho it...
It sounds like you need the timing adjusted in the projector. The pressure pads that hold the slide vertical in the projection gate are closing too soon. Check the Kodak website for the service procedure for this adjustment. If you need assistance, contact an authorized warranty repair dealer. Good Luck !!
Jul 14, 2011 | Kodak Office Equipment & Supplies
How to connect the sound equipment to the projector?
What type of sound equipment are you trying to connect?? What exactly are you trying to achieve?
There was a Kodak accessory called the Kodak EC Sound Syncronizer. This product allowed you to blend a music track with a slide projector control track that, once attached to a recording device, allowed you to have a pre-programmed slide show with audio. Is this what you are searching for??
Jun 13, 2011 | Kodak Ektagraphic III ATS Slide Projector
How do I open my Kodak Instamatic M70 projector?
I have a Kodak Instamatic M70 Super 8 movie projector. How can I stop the film from continously jumping? I have adjusted every nob and looked inside to find nothing out of the ordinary.
May 16, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
Everything works except for ther forward and backward rotation mechanism. When these buttons are pressed there is a buzzing sound perhap indication a motor problem?
This is a very common problem with these old Kodak projectors and is caused by a small part called the solenoid link that can be purchased separately or as part of this kit: https://www.micro-tools.com/store/item_detail.aspx?ItemCode=KODAK-KIT
There is also a guy on eBay, "atomk", who sells kits with very clear instructions on how to repair this problem yourself. Search for "Kodak Carousel Projector ADVANCE Repair Kit".
May 03, 2009 | Office Equipment & Supplies
GPS Logo
108 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
