I replaced the tcon board for double image on screen. After put everything together. TV turn on and got pictures and sounds but cannot access the sony xmb or menu screen. When hitting the display or home button to access the menu screen, i would get a message "powering on....please wait". But i waited for 1hr and still nothing happened.
SOURCE: DVD Recorder frozen - please wait on display
You need to replace the STR-G6353 voltage regulator on the power supply board. Full proceedure with photos at this link: http://www.rbjtech.net/electrical/e85/e85.htm#0 I did this on my DMR-E85H and it now works like new.
SOURCE: Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
SOURCE: No image on sony rear projection tv (model KP-53V35) for 20 minut
sony has a circuit than balances the 3 crt's. it needs a screen adjustment which is located in the front of tv behind speaker grill. easy repair
SOURCE: Replaced main board in Insignia NS-LCD19 TV and
Check all connections first,try agian.After that Change the LCD Inverter board might also dead.The inverter help backlight to screen to come on.
SOURCE: Sharp lc 32sh20u when power
WELL FOLKS I just FINALLY found what I have been searching for, I own a Sharp LC 32SH12U LCD TV that has begun to show problems with it's picture, Now it's sound is great no change..But it has gotten to the point that when i first turn it on all I get are three or four bright WHITE lines on the right side of the screen. They are a bout one third from the very corner of the screen.After it warms up for a while, MOST of the time it will just pop up and go to working just fine, that is what was giving it away to me that it HAD to be a something generally easy to fix, And in all of my searching I FINALLY found what I was looking for..Rite here on FixYA.com...There it was right thre in PLAIN ENGLISH..(( The T-CON BOARD )) Timing Control or LCD Controller..Board. on teh LCD panel Assembly, It transfers the image signal of the TTL and LVDS signal to specific TFT but What you all really NEED TO KNOW is JUST what is going on with your TV set when the T-CON Board is going bad, And I am about to tell you....So her ya go.. If you TV has any of these symptoms Well then I can pretty much say that your T-CON Board is bad or going bad...OK..If you have A Scrambled Picture,LINES,multiple Pictures Color smears, blotches, Rolling Pictures after warm up, Blown Surface mounted Fuse No Picture, Very Dark Screen almost like there is no backlight....Folks if your SHARP LCD TV is doing ANY of thsi then you just may need to replace your T-CON BOARD!!!! Hey it beats buying a new TV RIGHT!!!! GOOD LUCK FOLKS!!!!! I have already bought my replacement T-CON Board, as soon as I get it and install it I will let everyone know how it went!! PLEASE CROSS YOUR FINGER"S AND PRAY THAT THIS WORKS FOR US!!!! Thanks Wade in Eastman Georgia...
