Question about Samsung Heating & Cooling
What is the procedure to replace a samsung smart inverter air conditioner outdoor board
Posted by kevon steer on
5 Related Answers
harjeet singh
  • 86 Answers
SOURCE: Error CA for LG air conditioner model Q-12 AWR
1.sensar of remote control.
2.indoor unit sirkit board may be there is problem.change sirkit board by new one
3.if any requirement abt airconditioner pls mail me i can send u spare parts of air conditioner,.
[email protected]
Posted on Mar 16, 2008
Anonymous
  • 463 Answers
SOURCE: replacing inverter board for my sharp R-2130JS microwave
I do not know how to specifically replace the "inverter board" in this model. On most microwaves I've repaired, though, the hardest part is getting them dismounted from the wall if they are rangehood models. I suspect that the inverter board is held onto the chassis with two phillips screws, and all the connections thereto are modular and therefore easily disconnectable and swapped out. The great majority of times, manuafactureres do NOT put multiple connectors of the same pin count and oriention on a circuit board. Give it a go.
Posted on Feb 27, 2009
Anonymous
SOURCE: Air conditioner stop working after fall and lack
buy a f u c k i n g new one ya cheap c u n t
Posted on Oct 11, 2009
Dennis Boxerman
  • 1305 Answers
SOURCE: reset air conditioner samsung aqv12msan
http://nodevice.com/user_manual/samsung/other4/aqv12msan.html
Go to this web site. It has a copy of a user manual. May get the answer to your question as to how to reset.
Hope this does it for you.
Posted on Dec 03, 2009
Anonymous
  • 257 Answers
SOURCE: i have Fujitsu AOY36VMNB4 inverter multi split
EHello wgq66,
The in side unit is running and the outside unit is not.
This could be a of a few things things.
1. Power - check power
Check and rest beakers and fuses in the disconnect box. If good continue to next step.
2. contactor - the contactor tells the unit when to turn on.
Take the service panel off it is the little box with two big wire 220 volts (black
Posted on Mar 18, 2011
When we put on the air conditioner it shows F1 or ERROR on the window. What is the problem?
Hi Charity, F1 is a communication fault, I hope this helps......... CHEERS..
1?Check whether the connection of the outdoor unit and indoor unit is one to one, otherwise connect the L, N and communication line of the indoor unit and outdoor unit one to one.
2?Measure whether the voltage between the zero line and the communication line is 18V-30AC half-wave signal, check whether the communication circuit on the indoor and outdoor electric control board has been damaged, otherwise replace it.
3?Check whether the LED on the outdoor power board has been on, otherwise replace the electric control board.
4?Check whether the unit is abnormal caused by the external interference, if it is, then find the interfering source, and removes it.
http://www.chigo.bg/resources/pdf/Failure-code-manual.pdf
May 10, 2016 | grunaire GSI241HXB / GSU241HXB 24,000 BTU...
Is it possible to repair the outdoor pcb of the panasonic inverter air con?
It depends on where you are. If Australia, there is a company in Melbourne that can repair the boards. I have used them and they do quality work.
http://www.modulerepair.com.au/
Panasonic are pretty good for replacement parts though. Its worth pricing a new board first.
Apr 27, 2016 | Panasonic Heating & Cooling
After I replaced the pcb on my samsung air conditioner indoor unit it won't start and all 3 led's are blinking
I have had similar problems with Samsung. Apparently, the indoor board fits a lot of different models and each has to be "programmed" in to suit your model. Not sure what was wrong with your machine before but it has been known for these units to have a faulty outdoor fan motor which causes the outdoor board to fail as well. When this happens, the indoor unit will usually work fine for about a minute or 2 and then shut down, with lights flashing. The outdoor wont start at all. If these were the symptoms, I would suggest putting your old indoor PCB back and then getting a new outdoor fan motor and outdoor PCB.
Apr 19, 2015 | Samsung Heating & Cooling
HOW TO RESET A CODE ON A SAMSUNG SMART INVERTER MODEL NO AQV24uwbn?
Unplug it, then plug it back in. Unless you repair the cause of the error code, the unit will fault out every time it sees the error. It is basically saving its own life.
Feb 23, 2015 | Samsung Heating & Cooling
Fix serial signal fujitsu inverter asya09lcc
If it is serial signal reverse, the outdoor controller board has a problem. If it is serial signal forward, the indoor board has the problem. First check the the interconnect wiring is ok. If it is, one of the boards will need to be replaced and it is most likely the outdoor board (in my experience)
Feb 20, 2015 | Fujitsu Heating & Cooling
Code u 4 - Daikin model Rxymq48mvju
U4 Is a communication error between indoor and outdoor units.
usually means one of the PC boards is faulty. If unit has been freshly installed check wiring between indoor and outdoor 1,2,3 are the same colours on both boards.
May 04, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Daikin error code H6 Outdoor Compressor motor position detection sensor error
sir
daikin inverter air conditioner we are replace the indoor pcb then next it gone out door pcb,next we are replaced outdoor pcb also then compressor not working oftre last we are replaced compressor then it will be giving H6 ERROR CODE please give me suggestion
Feb 16, 2011 | Heating & Cooling
U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
May 28, 2010 | Cfm Daikin R410a Split System Air...
Heating & Cooling Logo
Top Samsung Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
