Have you tried using an external speaker? If you are using one, try disconnecting it and see what happens.
If you can't hear anything after these easy tests, you have something wrong inside that needs looking at by a qualified technician. Believe me when I say there is nothing that you can do to repair this problem if it is internal to the radio.
SOURCE: Uniden Phone 5.8 Ghz- I hear a spanish radio station
depening on your location if you have no interuption from other freqency from other leaking environment you r hanset may have a manufacture sorftware or hardware problems if you try another hand set wiht same problem posible a decfive ..
SOURCE: not receiving information
The same thing happened to me, and I'm just hitting the two-year mark with this thing. I tested it using the aux speaker leads and that still works. So it is only the little front-panel speaker that is broken. And I checked the leads on that little speaker, and they seem fine. So it is the little speaker itself that broke. Easiest repair is to connect the aux leads (red and brown) to another speaker.
