Question about Frigidaire Ovens
Need wiring schematic diagram for frigidaire wall mounting oven model#rg94ba-1-55cd please
Posted by M Walsh on
5 Related Answers
Anonymous
SOURCE: problem with tappan wall mounted oven
yes, the problem is fixed thanks to repairclinic.com. those guys are awesome and there is no fee for their help. the repair parts are cheaper than anywhere else i've checked and the tech support is second to none.
Posted on Oct 12, 2008
Anonymous
SOURCE: Need wiring diagram for old 1960's General Electric Wall Oven
55de40b.jpg Hopefully this will help. Don't know if it is the same model, but it is a 60s GE built in oven.
Posted on Jan 10, 2009
Anonymous
  • 56 Answers
SOURCE: i have a frigidaire model cfeb786jgb3 error
f1 is a watchdog on the control board
replace control
Posted on Jun 30, 2009
VtToolMan
Mark
  • 704 Answers
SOURCE: I need to change my oven ignitor and I need a diagram
Here's a diagram of the oven along with the Oven Ignitor (Part #19 on the diagram) and the Broiler Ignitor, (Part #26 on the diagram). They are located behind the gas deflectors located at the top and bottom inside the oven compartment, accessible from inside the oven, but you'll need to remove the rear panel at the outside back of the stove to disconnect the terminals tha supply voltage to the ignitors.
Be sure to turn the breaker off and/or unplug the range from the 220V-AC outlet first.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=FGF353BADB&productCategoryId=0124002&brandId=1428&modelName=FRIGIDAIRE-GAS-RANGE---5995274411&diagramPageId=00003&componentDescription=BURNER&documentId=Y2702738&backToLink=Return%20to%20Sub%20Components%20list
Hope this helps you complete your repair. Best Regards!
Posted on Jul 31, 2009
Anonymous
SOURCE: NEED A WIRING DIAGRAM FOR A GE
Click on the link below to view the wiring diagram for your electric oven
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=216042
Posted on Jul 07, 2010
Desperately searching for User Manual for Tappan Wall Oven Model 12-4990-00-04.
Hello Owner, thank you for your inquiry!
I understand that you need the use and care manual for your Tappan wall oven, 12-4990-00-04. If the model is older than ten years old manufacturers will not keep that information available. You might be able to perform a search for antique models online for any additional information. -Matt
Jan 11, 2016 | Frigidaire Ovens
I need a wiring schematic for a Kenmore model 79040522400 wall oven . Control panel the five wire that hookup on side for broil, bake, etc
diagrams are inside the control panel, usually in an envelope to the left or right side of center. If not there, look on the top or rear panels as they may be adhered to either of those. Worst case is someone took them from the unit during service in the past and never replaced them. Last option is to look online at sears parts direct. They show the diagram, but it is not clear.
Jan 26, 2015 | Kenmore Ovens
We have a Frigidaire Wall Oven that shows Err F3 - no buttons work. Model FSC88B-4 . The Oven temperature sensor measures at 1089 Ohms. There is 5 VDC on the control board. Tried resetting by removing the...
The sensor checks good. The only thing left to check the wiring between the control and the sensor. Check this for opens and shorts. If all checks good you will need to replace the EOC electronis oven control / clock. You can get diagrams and illustrations at www.appliancehelponline.com by entering your model #. All parts come with installation instructions.
Apr 15, 2010 | GE 24" Built-in Single Electric Wall Oven...
Oven doesn't reach temperature setting
It could be the plug/receptacle that the element plugs into. It could also be that the elements have separate thermostats and that the one for the lower element is bad. If you can post the model number I can look at the electrical schematic and know for sure if it has one or two thermostats.
Aug 31, 2009 | Frigidaire 30 in. Electric Double...
F3 message displayed
HI, you oven temp sensor if malfunctioning. the circuit is open. its basically dead. Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
May 22, 2009 | Frigidaire 24" Built-in Single Electric...
Kenmore Elite made by Frigidaire 30" slide in electric range model # 790.46603501 shows F30 ERR. Oven will not work. Range top is fine. Help!!! Turkey to cook!! Lynne
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 26, 2008 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
Ovens Logo
61 people viewed this question
Top Frigidaire Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Paul Carew
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
