Ovens Logo
Question about Belling Ovens
Wanted manual for e664 belling electric cooker
Have smashed inner glass door
Posted by Shirley Ann keefe on
Chris Huff
    Top Expert:
  • 6,289 Answers
Request directly from manufacturer
Posted on Nov 20, 2018
Testimonial: "Thanks Chris but I not got serial no"
5 Related Answers
Anonymous
  • 447 Answers
SOURCE: KEB5247 Kitchenaid built in electric double oven
Yes the inner door glass is a replaceable part and the door will have to be disasembled but not replaced. I can help with sourcing any parts for you since you used a premium post.
Posted on Jan 02, 2008
Anonymous
  • 833 Answers
SOURCE: how to replace inner oven door
Generally, the job is just alot of screws. Depending on the model, most screws are found either inside the door or on the lower edge. Some models...mostly GEs... have a way of removing the door from the hinge. Doors are heavy and are usually spring counterweighted.
Is it an easy job? Depends...if you're mechanically inclined it is straight forward. You will need an assistant as these doors do come apart and they are heavy. Often, the manufacturer or a parts house has an exploded diagram to let you see what you're facing.
Oh, and use a good quality screw driver and apply pressure when turning out screws. You don't want to ruin the heads!
Posted on May 27, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: how do i replace the inner glass on the oven door?
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Part here: _.gif PS2087058
Posted on Apr 08, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: broken inner glass on Model # NGSG3PZAQA
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
Part here: Inner Door Glass
Flipper
  • 18 Answers
SOURCE: the inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Posted on Feb 18, 2010
Please tell me if Electrolux EKG5547XN Cooker Main Oven Glass Door would fit my EOB6632U
Glass oven door is not compatible.
First of all, the oven door EKG5547XN has only two glasses, inner and outer, while the oven door EOB6632U has three glasses; inner, middle and outer.
EKG5547XN
Inner glass oven door, part number: 349 00 30-01/6, silkscreened; dimension: 456 x 323 mm, tempered glass.
Front glass oven door, part number: 349 10 45-14 / 6, stainless.
EOB6632U
Inner glass oven door, part number: 899661 92 68-78 / 3,
silkscreened; dimension: 479 x 391 mm, tempered glass.
Middle glass oven door: dimension: 447 x 380 mm.
Front glass oven door: dimension: 589,5 x 466 mm.
Dado
Replacement user manual for Belling Format 645 cr double oven electric cooker
http://www.manualsonline.com/mdownloads/ff2c5d47-49a9-4d8c-9232-8033f1e3e147.pdf
The inner glass on the oven door has smashed on my Stoves heritage 720EF. Where can i get a replacement? Thank you
Try espares. If it is not listed, there is a section where you can specify the part you want and they will come back to you with a price if it still available.
1helpful
How hard is it to replace the inner glass in the oven door?
not a train smash, locate screws to seperate the two door halves to allow access to the inner glass. remove screws and plates holding the broken glass. clean then place new one in possition and tighten screws comfortably tight.(dont over do it).Reassemble door.
Sep 14, 2009 • Ovens
Broken outer panel of glass on cooker door
I found a replacement for my oven on ebay. Be careful, though, because one seller offered one that was the wrong size.
Apr 01, 2009 • Ovens
Smeg se336ss 5 some so and so has broken the outer glass door!
We removed the front glass of our oven door after a big spill between the two glass sections (by blunt force!). Since it took us 4 hours to put back together, we wanted to spread the info in case any others have the misfortune to make this mistake! Note, I wouldn't do this unless you have to, just incase you can't get your door back together again.
Assuming the back sheet of oven glass is still in position, but the front sheet is not attached -
1. Follow the manual instructions to remove the door, ensuring that both hinges are locked fully (otherwise you won't be able to get the door back on easily)
2. Once the door is removed, ensure that the plastic spacers that hold the two sheets of glass apart are in original position, resting on the inner door, at the bottom corners of the tempered glass
3. Remove the narrow metal strip at the bottom of the inner door by unscrewing the 3 screws that hold it in place. This is the metal groove that the outer pane of glass needs to rest in
4. Lay the outer sheet of glass in position in this metal strip
5. Lay the outer sheet of glass over the inner door. Slot the outer sheet into position at the top of the inner door first, ensuring it is layed flush at the top.
6. A second person needs to ease the metal strip back into place at the bottom of the inner door, so that the two sheets of glass are now held together at both top and bottom.
7. Screw the metal strip back into position with the 3 screws
8. Follow the manual instructions to replace the door. Ensure that the small grooves at the bottom of both hinges are resting in position correctly, otherwise the door will not close flushly.
Bosch hbn41 ..43
BOSCH COOKER HBN41/43 GLASS ON INSIDE OF OVEN DOOR SLIPPED AND SMASHED
Cooker
HI THERE SKI IS THE GLASS DOOR PANEL THE INSIDE DOOR GLASS OR THE OUTER DOOR GLASS PANEL AND IS IT THE MAIN OR TOP OVEN.
THE GLASS PANELS INTERNALLY ARE HEAT BONDED IN THE FACTORY AND CANNOT BE REPAIRED YOU WILL NEED A NEW DOOR GLASS.
IF INTERNAL ONE COME AWAY THEN U WILL HAVE TO HAVE A COMPLETE INNER PANEL.
Feb 13, 2008 • Ovens
Top Belling Ovens Experts
Marvin
Marvin
Lawrence Oravetz
Gil Shultz
Are you a Belling Oven Expert? Answer questions, earn points and help others
