Question about Sewing Machines
CREATIVE 7530 SEWS ALONG, NEEDLE PUSHES THROUGH FABRIC & THEN JUST STOPS
Posted by MARI PAHL on
MissFixIt828
    New Friend:
  • 70 Answers
Your needle could be bent.Trying changing your needle and move the hand wheel by hand to see if it still hits. If it does, the hook timing could be out.
Posted on Nov 20, 2018
5 Related Answers
Anonymous
SOURCE: Machine stops and sews in place
sews only one stitch at a time and have to wait a few seconds before it will do this
Posted on Dec 16, 2007
Anonymous
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
Anonymous
  • 297 Answers
SOURCE: My Janome JD1818 will sew in reverse but not forward.
Switch broken, have it replaced
Posted on May 06, 2009
deborahcha
  • 371 Answers
SOURCE: I have the Scandia probably 5 yrs old...feed dog
The feed dog motor needs re-calibrating. If recalibrating does not resolve the problem, the feed dog stepper motor may need to be replaced. These tasks have to be done by a certified Husqvarna Viking service technician. Suggest that you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Posted on Feb 14, 2010
Mary Dunn
  • 1788 Answers
SOURCE: Needle moves up and & down and sews for a few
If you look at the website, www.sewvacdoctor.com and you can see, they say it may be your foot pedal or transducer(speed control inside the machine) I would call Singer and see if it is still under warranty, hopefully it is. If it is the foot controller, that is not too expensive, I don't know about the transducer. But, call Singer at -800-4singer and tell them what is happening. Good luck
Posted on Oct 11, 2010
Hi I just purchased a used Juki DDL-555. 1) It will not catch the bobbin thread. 2) it will not sew forward and feed the fabric along (it sews in reverse just fine). Can someone please help?
the material movement is set by the forward/ reverse knob or lever
not picking up the thread can be needle thread tension too loose
it can be needle hook timing
Apr 20, 2017 | Juki Sewing Machines
Needle does not penetrate the fabric when using the T foot, but sews in the air
think you have to put that foot down same as any other foot
Aug 17, 2015 | Sewing Machines
Sews 1/4" and then sews in place
1) remove upper and bottom threads. Try sew without threads.
Is fabric transported corectly?
NO:
- Drop feed dog button is OFF
- Dust under stitch plate
- Transporter malfunction (must be taken for a service to the BERNINA dealer)
YES:
- Upper or bottom thread jammed
- The upper thread tension is too tight.
- Wrong needle used (probably small ...)
Nov 20, 2013 | Bernina Bernette Deco 600
I have a Pfaff Creative 1475 CD. It only skips stitches on stretch materials. I have tried a ballpoint and stretch needle and it still skips stitches. It sews a 100% correctly on any other type of...
There are a couple things you can do that may help. 1. Float some lightweight paper under the fabric. Sew through the material and the paper. Then tear away the paper.
Secondly make sure you are using a long enough stitch.
If none of these things work.... take it in and have an example of the skipping. Have the machine's timing checked.
Oct 30, 2013 | PfaFF Creative 7570
Needles keep breaking when embroidering.
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
Oct 17, 2013 | PfaFF Quilt & Craft Pro 7530
HELP PLEASE!!
I am slightly familiar with older sewing machines but not modern machines. It is a long time since I've seen my machines.
If your presser foot has a wide slot it is clearly possible to use it for zig-zag sewing. If the machine is capable of zig-zag or swing needle sewing, it is sometimes possible to swing the needle and fix it to the left or right and fix it in that position.
I suggest you check in your machine instruction manual. Perhaps the presser foot you are using is unsuitable for your machine...
May 12, 2017 | Juki DDL-8300
My kenmore mini ultra is bunhching the tread by the bobbin
try changing the needle--normally flat side goes to the back of the machine
make sure the thread & needle are correct for the fabric being sewed
rethread machine top & bobbin
make sure top tension is adjusted according to fabric & thread
Apr 06, 2012 | PfaFF Quilt & Craft Pro 7530
My Fashion Mate 6160 beeped and stopped sewing & automatic threader doesnt work
if the machine still sews a straight stitch on top of fabric & also on bottom then it should be fine..
it's possible that the thick fabric, needle, & thread were not a compatable combination.
but also some sewing machine are not made to sew thick or heavy
fabric
but having the machine serviced would be a good idea & help to know why the needle thread is not working
Jan 17, 2012 | Sewing Machines
Machine stops sewing when I hit a thickness
it may be that your motor belt needs tighening or the belt may be damaged - you can check belt and adjust tension yourself once side cover is removed.
if you are sewing thick seams and the needle is resting on the seam as you begin to sew you may have to help the machine to get started. if the fabric is not thick it must be belt tension.
scott.
Jun 17, 2009 | PfaFF Hobby 4260
Dec 16, 2006 | Husqvarna Lily 540 and 550
Sewing Machines Logo
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
