Question about Singer Sewing Machines
Singer Starlet 6600 timing off. I am a new sewer and need help.
Posted by Vickie on
  • Kristi Derschmidt Mar 06, 2019
    I just got a Husqvarna Viking emerald 116 sewing machine and the needle will not go up and down. I have the handwheel press to be in position so it is not in the Bobben winding position. Any ideas?
Carl Rock
  • Singer Master
  • 2,447 Answers
Are you able to bring bottom thread to top? If yes, then likely timing is OK.
Otherwise rethread, top and bottom, machine per manual instructions;
http://www.singerco.com/uploads/download/dc862aba627092eb72f3e21b48071579ad028aec.pdf
Comment below so I may assist further if need be.
Posted on Mar 06, 2019
MissFixIt828
    New Friend:
  • 70 Answers
Try changing your needle. A dull/damaged/bent needle can cause timing and tension issues. If you are sewing through anything heavy/thick layers or anything with stretch, make sure you are using the correct needle size/type. If the timing is actually out, it’s best to take it in for repair.
Posted on Nov 20, 2018
The bobbin thread wont plck up on singer starlet model number 6699
are you holding both the needle and bobbin thread below presser foot .
Jan 16, 2015 | Singer Sewing Machines
I have a used Singer Starlet 496. The bobbin no longer winds. I took it for an estimate and was told that the winder had seized and they were unable to fix it. Can I do anything on my own?
Try Kroil; put in the places where metal rubs on metal. Or, you can try sewing machine oil. Place a drop of oil every place that metal rubs on metal, or, plastic on plastic. Let it sit a few days.
Jul 20, 2014 | Singer Sewing Machines
Singer user guide starlet 496
Many Singer machine manuals are available here: http://www.singerco.com/support/instruction-manuals . The 496 is not available. However, the manual for the Starlet 495 is available: http://www.singerco.com/uploads/download/8a78e29267b106e9d2902ac0f6758edf694e6d61.pdf . Since Singer doesn't change the machines significantly, this manual may help you.
If the 495 manual isn't enough, this site seems to have the manual for sale: http://www.manualsdrive.com/captching.php?lang=en&search=SINGER+STARLET+496+USERS+GUIDE .
I hope this helps.
Sep 01, 2012 | Singer Sewing Machines
The upper thread in the backside of the cloth comes bundle and after few stiches the wheel stops with the thread jam in the hook of bobbin. i kept thread tension at 3, 4 and 5 ,cleaned the bobbin and...
Wow, what a challenge. There are a lot of reviews/complaints about how temperamental this model is- sewers either love it or hate it and have the same problems you describe. Since I am an experienced sewer and have lots of vintage black Singer models, ( I got rid of the newer models), I wouldn't mess with it any further...If you can, take it to a Singer authorized repair person....they can sort it out for you. Sounds like you've done everything you could so far. Good Luck.
Jul 23, 2011 | Singer 8280 Mechanical Sewing Machine
Bobbin case futura singer sewing machine came out
The opening fits on the right side, toward back. There is the silver ring with the slot in it for the bobbin. That slot is facing the sewer.
Jul 19, 2009 | Singer CE-100 Futura Computerized Sewing...
Manual for singer 1507
I scanned my manual and uploaded it to a file sharing site here is the link to the file:
www.4shared.com/file/133426020/8af58505/Singer_1507_manual.html
I only scanned in the English pages, I hope that is not a problem.
Mar 20, 2009 | Singer 1507
Sewing Machines Logo
74 people viewed this question
Top Singer Sewing Machines Experts
tsalagi152
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
