Question about Hisense Televison & Video
Inch HIsense tv a thetv menu keeps popping up, what do I do?
Posted by Larry Brantley on
David Spradling
    Top Expert:
  • Hisense Master
  • 11,320 Answers
Go into settings for picture and remove
Posted on Nov 22, 2018
5 Related Answers
Anonymous
  • 106 Answers
SOURCE: Menu keeps showing on my TV
Your tv needs a software upgrade. This is usually done by a qulified service technician.
Posted on Nov 26, 2008
Steve Yocum
  • 668 Answers
SOURCE: My menu keeps popping up tv and my volume dont work
Most of the time this is caused by one or more of the front panel buttons being bad. I would have all of them replaced.
Posted on Jul 16, 2009
Anonymous
  • 63 Answers
SOURCE: THE MENU KEEPS POPPING UP ON THE SCREEN CONTINOUSLY ON MY 42 INCH
I had an LG 37" LCD that did this to me. Turned out to be bad solder joints on the side button board. Just reflowed and it starting working fine.
But now that I think about, I had another set do the same thing, only it wasn't the button board. I had to upgrade the TV's firmware via the USB service port. Just needed a USB flash drive and downloaded the firmware from the mfg's website. There were easy to follow instructions there too!
Posted on Dec 16, 2009
  • 18378 Answers
SOURCE: My hisense tv menu keeps popping up and sound going up and down and select source keeps popping up to
Hisense support is very good but this issue may be a firmware issue. They can send You an update for the firmware but I have not had any luck using them.
Posted on Apr 10, 2017
brian williams
  • 1864 Answers
SOURCE: i have a hisense 55 inch smart tv while watching it i heard a pop sound then tv went off what could of it been whats wrong wi5h it wont turn on
Probably a capacitor on power board popped.
Posted on Nov 11, 2017
Apr 10, 2017 | Hisense Televison & Video
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers · Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
Mar 20, 2013 | Hisense Televison & Video
My Hisense lcd is lock.
This is how I got mine to work after weeks of struggling just trying to find a new remote (hisense is really hard to contact....).
1) Turn the TV ON. unplug the tv while still ON 2) hold down the "menu" button on the side of the TV and plug it back in. keep holding it down. the TV should turn on with the menu popping up. use the Vol <> keys and Channel <> keys to navigate the menu. go to the Vchip menu, and play around. I'm not sure what ultimately worked, but i changed the Vchip password to 1111, turned the reset menu to "on" and played around with the ratings settings (turning most of them to "u"s etc).
I went through this process several times and finally, the black background behind the menu turned to static. I played around with the channels, and the TV was unlocked. I turned the TV off, and then on again, and the channels showed up normally (no static). and it was no longer locked. I had to do the unplug thing several times, and was getting really frustrated looking for an "unlock code" in the manual (it just says press the button on the remote. so it was not really helpful).
But really, once you can just get to that menu you've made some progress, and just keep playing around with it until something works.
Best of luck!!
Jun 03, 2008 | Hisense TL1700 17 in. LCD Television
Hisense TL2020 LCD TV
Try turning the main power switch on the back of the tv off.
Then hold the menu button and push that switch back on while still holding the menu button.
Keep holding the menu button until the setup menu pops up.
Next, be sure your input is set correctly(air or cable).
Next, do an auto channel search.
That did it for me. After I shut it off I had to do it one more time but it did the job. A friend of mine gave me the tv for free because nobody he new could figure it out. I took it home, got lucky, and figured it out in about ten minutes.
jb
May 23, 2008 | Hisense TL1700 17 in. LCD Television
Televison & Video Logo
1,216 people viewed this question
Top Hisense Televison & Video Experts
Sean Burke
Sean Burke
David Tickner
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
