Question about Optics
I know there are replacements that will work but I can't find anyone that has one. Can you help me please ?
SOURCE: Nikon ProStaff Laser 440 not working
Here is the address to send your rangefinder for repairs.
I had the same issue with my Nikon Laser 800 rangefinder. I sent it in and they wanted $311.00 to fix it so I bought a new one for $300.00 off EBAY. Today I was missing around with my old rangefinder and noticed after I put the battery in I could hear something loose in the rangefinder. There is a little metal tang in the bottom where the battery goes that holds tension on the battery that was bent down. I bent it back up about 3/16" and put the battery back in, now it works fine.
Posted on Mar 13, 2008
SOURCE: I just replaced the front cover of a 2003 Ford, Ranger, 2.3
there are no timing specs for that vehicle, the vehicle pcm does all of that. always mark your gears and chains when you take them off. if you just replaced the cover and thats it, there should be no reason why you would have to set the timing-
Posted on May 19, 2009
SOURCE: need the proper tool for a nikon prostaff range finder
Harbor Freight has a kit that has them in it and most industrial tool supply companies have them. It's a security screw. there are many kits availably with an assortment of bits in them. Drill Master has a 100 piece kit that's pretty cheap. Item#91310
Posted on Oct 29, 2009
Testimonial: "Perfect. Huge Help. Thanks"
SOURCE: MY NIKON 550 RANGE FINDER
Same problem. Conclusion: just because it has the NIKON name does not mean it is not a piece of Chinese junk.
Posted on Nov 09, 2010
SOURCE: I can't get my Nikon Prostaff 550 Laser
I have the rifle hunter 550 , and I have replaced the batty and now it will not turn on at all any questions, sorry to awnser with another question., but the web site will not let me post it.
Posted on Jun 29, 2015
Nov 07, 2014 | Nikon ProStaff 550 Laser Rangefinder
Feb 01, 2011 | Nikon ProStaff 550 Laser Rangefinder
Oct 20, 2010 | Nikon ProStaff 550 Laser Rangefinder
Jul 23, 2010 | Nikon ProStaff Laser 440 Rangefinder
Nov 16, 2009 | Nikon ProStaff Laser 440 Rangefinder
Oct 27, 2009 | Nikon ProStaff Laser 440 Rangefinder
Oct 23, 2009 | Nikon ProStaff 550 Laser Rangefinder
Oct 15, 2009 | Nikon ProStaff 550 Laser Rangefinder
Dec 01, 2007 | Nikon ProStaff Laser 440 Rangefinder
Oct 12, 2007 | Nikon ProStaff Laser 440 Rangefinder
238 people viewed this question
