Question about Home
My Berger lamp oil evaporates quickly. Filled my bottle 3/4 up and used once and when I went to light it again the oil was empty
Posted by Mary on
5 Related Answers
Anonymous
  • 64 Answers
SOURCE: coolant light stays on
check your hoses and look for leaks at the water pump, also look at radiator for leaks.
Posted on Feb 18, 2009
Anonymous
  • 108 Answers
SOURCE: 1991 mr2 oil warning light
try to disconnect battery behind drivers seat to reset computer then check oil pressure sensor
Posted on Mar 31, 2009
ILikeBMW
ILikeBMW
  • 117 Answers
SOURCE: My BMW 323C slow down quickly when my foot off the pedal
hello there
Thats interesting considering these BMW auto boxes have about 10 quarts of oil in them, when chainging the trans oil not all of it comes out but it should be at least 5/6 quarts. You need to get the oil level checked asap.
Hope this helps, please don't forget to rate me.
Posted on May 19, 2009
ftw1952
frank thomas wilson
  • 10319 Answers
SOURCE: service engine light comes on if tank is filled up
Here is a website that a free manual can be down loaded for your vehicle
http://ezinearticles.com/?Find-the-Free-Auto-Repair-Manual-You-Need-Online&id=92717
Posted on May 01, 2010
Anonymous
SOURCE: 1998 Buick Park Ave started
Bad head gasket
Posted on Nov 05, 2010
How do you oil a Craftsman Air Impact Wrench Model No. 87518846
If you are just oiling the gun,hold it upside down and squirt some oil ine the air chuck fitting.(I just use an empty bottle of my wife's hair dye filled with ATF-it's cheaper than a can of "air tool oil".If you are referring to the grease fitting for the impact mechanism,look for a small hole with a captured metal ball.The only tool I found to fill this is a specially designed miniature grease gun(got mine at Sears).
Jun 13, 2012 | Craftsman 3/8 in. Pistol Grip Impact...
Yes it is normal just no hot air
1. When setting the temperature to MAX, blower level to FULL and outside air Vent CLOSED, no hot air comes out after 2-5 minutes?
If YES, when did you last flushed your radiator and is it full?
2. if more than 5 years ago, flush radiator system, instructions are usually in Owners manual. Use a bottle of Radiator cleaner, run egine hot for about 10-15 minutes, carefully open petcock in bottom of radiator to flush out radiator, WARNING, careful as flushed coolant would be boiling hot. As sson petcock is open and water start to flow out, carefully open radiator cap to enhance flushing flow. Use garden hose to fill radiator while flushing until water coming out from petcock is cold and clear.
Once clear, start engine, turn heter full and blower full blast and keep hose in radiator flowing full, leave petcock open until clear water flows out again. Once clear waters comes out, turn off engine,turn off garden hose and let water drain empty radiator. Once it stops flowing out, close petcock snug and put radiator cap on, pull off radiator coolant catch bottle, clean bottle for any debris and dirt. Drain any water, leave bottle empty and put it back onto its place.
3. Fill radiator with 1 gallon (4L) of concentrated coolant, top up radiator until full, fill catch bottle with concentrated coolant, start engine and keep it overflowing until no bubbles comes out and the radiator is fully hot. Once it is flowing good, close and connect everything. Drive with it and keep catch bottle filled as necessarry.
Good luck. Give as vote and good comment if this advise solve youor problem. Thank you.
Jan 05, 2011 | 2000 Chevrolet Suburban
Oil leak. Even when car is not running .the car is not smoking, but using an extreme amount of oil.
Go to any auto parts store and purchase a bottle of engine oil dye. You will also need an Ultra Violet Lamp which can be purchased at most pet stores, drug stores, and hardware stores. Follow the directions as labled on the bottle and you will find the leak source fairly easy and quickly using the UV Lamp as required
Mar 30, 2010 | 2003 Chevrolet Impala
Since 3 weeks my Siemens freezer (No-Frost system, 5 drawers) sounds the alarm and cannot uphold its temperature of -18. Could it be that coolant is evaporating instead of leaking (no traces there). And if...
you need to empty the freezer, unplug it for a day . at the back near the bottom is a plastic recipient which will be filled a couple of times with water. not so easy to empty.
I had the same problem 6 months ago, and today once again
so nofrost ? seems to have some problems.
Mar 09, 2010 | Kitchen Appliances - Others
My grill would not preheat to proper temperature for several uses.Then it would not light,there was no gas smell from the burners.
Sounds like your propane bottle is empty...or maybe you have a bad regulator. Disconnect your propane bottle and pick it up; if it is very light, you need to get the bottle filled (or exchange it for a full one, depending on the type of bottle you have). If the bottle has plenty of gas, change out your regulator.
Dec 03, 2009 | Grilling
hello there
Mar 12, 2009 | 1999 BMW 323 Series
Coolant light stays on
Feb 18, 2009 | 1996 Pontiac Sunfire
Gas gage constantly says full when it's not!
Unfortunately this is most likely the fuel pump module, which includes the fuel level sensor also. This should be diagnosed more thoroughly with a scanner, a good scanner will be able to check instrument cluster separately to confirm the gage is working right,and check for trouble codes that may not light any warning lamps. Hope this helps. Rate me please.P.S. Dont use that fuel station any more.
Jan 21, 2009 | 2002 Chevrolet Malibu
OIL
i think around 3.5 - 3.8liters not quite possitive but if its empty from an oil change that should be fine on level ground once you have filled it wait a minute then check the oil level on the dipstick you cant go wrong
Jun 11, 2008 | 1993 Honda Civic 4 Door
Home Logo
88 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
