Question about Home
I need a new Gemma Santa head...mine fell off the bay window and cracked all around his head.are they for sale
Posted by Susan Kay on
Singing santa 4ft his head does not move any more. dancing sound pops and crack and then just stops.push the button and nothing unplug and replug some time that works to get him mover
You might want to check the electronic component in your "singing Santa", this sounds like a short of a sort...and can be dangerous if not watched while in use. The pops and cracks sound like the electronic system that makes the head move might be dirty. If this is a new display item, return it and ask for a refund, if it is older, check for dust bunnies in the electronics of it...you can use compressed air to clean it out, and might get functionality back. Best of luck with Santa* Michelle~
Dec 21, 2017 | Miscellaneous
Power window fell down, won't roll back up
I just had that happen on a 2000.
It was the window regulator.
I ordered a new one on e-bay.
Changing it involves taking the whole door apart, and you can do it yourself, if you are really "mechanical".
You would need to pay particular attention to where every nut & bolt goes, and replace exactly.
The window regulator is made of several metal pieces and some connecting wires or cables.
It is complicated if you are not familiar with it.
You will be needing to take the glass out of the door by rotating it, so you can install the new regulator.
Be blessed.
Mar 16, 2013 | 2002 Chevrolet Impala
Need Help 97 BMW 528i Head gasket job
I JUST finished mine on my 97 528i. Bad news tho. The head typically cracks because the cooling ports are 1/2 in away from the head. Mine cracked in 3 places. I ended up going to a junk yard and found a head that they resurfaced and re did the valves for $600. Start looking around because your head a almost Garrantee it's cracked.
Dec 13, 2012 | Cars & Trucks
Need to reattach the rear view mirror. It was bumped off the window
You can get a kit for this. Just look at a hardware store or auto parts store
Jun 10, 2011 | 2004 Hyundai Santa Fe
How to take door panel of? window fell off of track i beleieve
there will be 2-4 screws you will need to unscrew. usually one located around inner door handle and 2 of more around arm rest and maybe some on the lower part of the door and panel. the screws are usually covered by plastic covers. you can remove these with a small flathead screw driver to find the screws. after all screw have been removed carefully pry the panel off with plastic pry bar to prevent scratching. it will literally "pop" off with clips. be careful, you dont have to use tons of force, check to make sure all screws have been removed. then the panel will hang there because its still connected to lights, switch, and door handle. remove these connectors and the panel will come right off. if the window fell off the track, it might be as simple as screwing it back on the window regulator. worse case the regulator linkage is cracked and you will need a new window regulator.
May 04, 2011 | Cadillac DTS Cars & Trucks
110.000 miles 1998 Check engin light says misfire cyl # 4 Mechanic says I have cracked #4 cyl and need a new head. Is there a cheaper work around repair
if the head is cracked then you have no choice here but to replace it, there is no work around for serious problems like this, sorry
Jan 25, 2010 | 1998 Ford Expedition
My imac screen got shattered cause the computer fell, it still works can I get new glass for the screen
Yes you can. You can go to an authorized Apple repair center, or you may find on for sale as a part on a site like e-bay.
Jul 30, 2009 | Apple 24" iMac Desktop
Cracked screen for Tomtom One XLS
Look for a screen on e-bay, I found one and found it simple to replace. MAKE sure the screen is the right one for your GPS
Jun 30, 2008 | Tomtom One XL GPS Receiver
Home Logo
66 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
