Question about Golf
Eletric yamaha golf cart will click and trt fowerd but will stop within seconds. Batterys reed 47volts ,,,, I do here the solinoid click on ...could this be going bad? 9
Posted by Joe Farrar on
5 Related Answers
Anonymous
SOURCE: 1982 e-z go electric golf cart needteck sheet.
I have a 96 EZ GO gas golf cart with loose steering. What parts are normally needed to correct this problem and are special tools required for me to replace the parts.
Thanks,
Bob
Posted on Jan 22, 2009
Anonymous
  • 24 Answers
SOURCE: I have a yamaha electric golf cart. The lights
I bet that it is an simple as a fuse that blown out. Try replacing the corresponding fuses.
Posted on Nov 07, 2009
Brandon Undeberg
  • 174 Answers
SOURCE: golf cart smoking
It is most likely related to the rings, but running it would unstick them very fast if they were stuck. It's possible that sitting let rust develop in the cylinder walls and there may be some grooves in them now. They could also just be really worn cylinders. They make some oil conditioners which I wouldn't recommend on a car, but might work fine on a golf cart. I can't recall the name, but it was in a silver can, maybe called engine restore... You could always try that before resorting to a rebuild.
Posted on Nov 12, 2009
Testimonial: "thanks for your advice. I will try an additive before a rebuild."
golfcartman
  • 34 Answers
SOURCE: i HAVE A 1999 ez go cart and we smelled burning
Look under the cart and make sure the wires to the motor are good.
Posted on Apr 21, 2010
Anonymous
  • 16 Answers
SOURCE: Hi I just brough a yamaha golf cart and wanna know...
check the serial number there is normally and date with in it.
Posted on May 21, 2010
Nov 07, 2009 | Electronics - Others
I HAVE A 1999 ez go cart and we smelled burning
Oct 01, 2009 | 1995 Volkswagen Golf
Can I leave my 2004 ezgo golf cart charger plugged into the golf cart and wall all the time when golf cart not in use?
never leave charging all the time you want to charge it every 6 hrs of running time to let your batterys cycle down. it would be the same if you charge your cell phone everytime you make a call if you cant keep track of it get a state of charge its a volt metter like a gas gauge for the batterys if you do it my way you will get more run time and your batterys will last around 10 yrs if keep doing it your way them about a couple yrs on them
Jul 21, 2009 | Electronics - Others
Thanks,
Bob
Jan 05, 2009 | 1995 Volkswagen Golf
Golf Logo
313 people viewed this question
Top Golf Experts
ray gallant
Bill Boyd
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
