Logitech QuickCam Pro 9000
Hello. I am contemplating using the device for Astronomical spectroscopy, after removing the lens and attaching to a telescope.
Can you tell me :
>The pixel size (or the physical dimensions of the 1600x1200 pixel detector)?
>If there is an IR filter which can be removed, and the QE after removal?
>The longest exposure possible?
Thanks,
Keith Forbes
Posted by Keith 4BS on
5 Related Answers
Anonymous
  • 1463 Answers
SOURCE: INSTALL THE LOGITECH QUICKCAM FOR NOTEBOOKS PRO LENS 4.9MM
hi
have a look here on there site see if yours is listed Logitech > Support + Downloads > Downloads > Webcams
riz.
Posted on Apr 18, 2008
Anonymous
  • 35 Answers
SOURCE: cannot install quickCam v11.7
If you are using windows xp then you should download this fix from the microsoft website. http://www.microsoft.com/downloads/details.aspx?FamilyId=C717D943-7E4B-4622-86EB-95A22B832CAA&displaylang=en
If you are running windows vista please follow these instructions carefully.
  1. Click on "Start".
  2. Click on "All Programs".
  3. Click on "Accessories".
  4. Right click on the Command Prompt, select "run as administrator".
  5. At the prompt, type "regsvr32 vbscript.dll".
  6. You will now get a message box saying "vbscript.dll" has been registered.
  7. Reinstall QuickCam
I hope this helps. If not let us know.
Please rate my answer
Posted on Aug 17, 2008
Anonymous
SOURCE: No video when using quickcam pro 9000 on google chat (gchat)
I had this problem but I fixed it. The google chat uninstaller does not uninstall everything. Go to the hidden folder Application Data of the default or local user in the Documents and Settings folder of the C drive, you will find the plugin folder for google chat. Delete it and then reinstall the plugin and it will work.
C:\Documents and Settings\Joe\Application Data
Posted on Feb 05, 2009
Anonymous
SOURCE: Can't get Logitech QuickCam Pro 9000 to work on Gmail?
Anonymous
SOURCE: Mac Software for Logitech QuickCam Pro 9000
The solution (or, should I say "supposed" solution) posted by yooperbud is 100% wrong, wrong, wrong. As a matter of fact, he couldn't BE more wrong. While the original question asked had to do with software for the QuickCam Pro 9000 for the Mac, the answer he gave is 100% directed at the Windows OS, NOT the Mac. To anyone, and everyone, who has voted his reply a "Yes", I am sorry.
Posted on Aug 02, 2009
I bought a basic Meade DS 2114 GOTO astronomical telescope for my father who is only just getting into telescopes and astronomy. As both of us are just beginners and mainly use the telescope leisurely, we...
NO it is NOT missing a lens-- all astronomical telescopes show upside down images.
You can buy an "erecting prism" diagonal for terrestrial viewing, but you do not need it to view the night sky.
Here is an example of the erecting prism:
http://www.astronomics.com/main/product.asp/catalog_name/Astronomics/category_name/EDNECFUVSRWS8KLNTU5E38XSE1/product_id/6329
Aug 23, 2010 | Meade DS-2114 ATS (325 x 114mm) Telescope
Just came into a used tasco 302048 . Everything is upside down!!!
the scope is made for both terrestrial viewing and astronomical. In order to see terrestrially upright, you need an inverting STAR DIAGONAL. The eyepiece will do nothing for inverting the image. you might have 2 diagonals in the kit that came wih the scope. the diagonal is the part that fits into the scope. then you place the eyepiece in the diagonal. if you have 2 diagonals , one is a 90 degree angle,(astronomical) and one is a 45 degree angle, (terrestrial). the eyepieces change the magnification of the image. the bigger the number (9mm, 20mm, 26mm,) the smaller the image. the smaller the number , the bigger the image gets. the number is inverse of the image. Hope this helps.
Jul 01, 2009 | Tasco Luminova 40060660 (660 x 60mm)...
Trying to identify older tasco telescope and put it together
There are only two types of telescopes --- REFRACTORS, and REFLECTORS-
The refractor has a lens on the front of the tube and you insert different eyepieces in the back-- the larger the number written on the eyepiece the LOWER the magnification-- (DO NOT USE THE 2x or 3x barlow which you may have!-- this creates too much power for this small telescope!-- put it away and never use it!)
A reflector has a main mirror on the bottom of the tube, and a small secondary mirror under the eyepiece hole (focuser end) - front end-- put the lowest power eyepiece into the focuser.
Now with either type telescope go out side during the day and practice focusing on a distant object-- turn the knob SLOWLY. At night the moon should be the first target you try.
If you received what appears to be a smaller telescope -- that is the finder scope-- attach it to the top of the tube on the main telescope. Again during the day line up the small finder scope with the main scope-- look at a distant telephone pole (the very top-- and center this in the main telescope. Without moving the main scope use the finder scopes "screws" to adjust the cross hairs so they are pointing exactly where the main scope is pointed. Now you can use the small finder scope to point the telescope in the exact direction--
The moon should be your first night time target.
Good luck--
Mar 17, 2009 | Tasco Astronomical 302675 Telescope
THINGS UPSIDEDOWN
It's the nature of the way telescopes work that means all images are seen inverted. For astronomical use, this isn't really a problem.
You can buy an "image erector lens" to correct the image and see it rightside-up though.
Dec 29, 2008 | National Geographic 76AZ (525 x 76mm)...
Inverted image
All images in astronomical telescopes are upside down and reversed-- this is normal. There is no up or down in space. Reversing the image just adds more GLASS to the light path.
Nov 13, 2008 | Bushnell NorthStar 78-8846 (675 x 114mm)...
Missing finder scope
i actually have the star finder and its **** honestly. but well mine is old to. so a new one might do you better. but i've attached a rifle scope to mine.
Aug 04, 2008 | Tasco Astronomical 302675 Telescope
Tasco 57T Telescope
Loosen the set screw and it pulls off.
Jun 21, 2008 | Tasco Astronomical 302675 Telescope
Upside down sight
You need a 'spotting scope' adapter to right the image using a prism.
Jun 21, 2008 | Bushnell NorthStar Goto 100mm 788840...
Hi we cant seem to see anything from our tasco telescope
It is very difficult to align a straight telescope on small objects like stars and planets. The moon is an easy target, try locating it 1st
Dec 28, 2007 | Tasco Astronomical 302675 Telescope
Computers & Internet Logo
283 people viewed this question
Ekse
Marvin
Marvin
