You can't. You need a new ignitor. The only way to do it would be to change to an older style gas valve with a standing pilot and a thermocouple. This would be cost prohibitive. Also, if this is a power-vented heater, you can't change to conventional pilot because the gas valve links to the control circuit for the blower. An old gas valve does not. Good luck!
SOURCE: General Electric GE SmartWater heater problem
most units from GE come with a 3 year manufactures warantee and the home depot should have no probleme giving you a new one off the shelf with your receipt they will send it back and get there money back from GE so they pass it on to you. it would cost you the same amount to fix that one then to buy a new but yours is still under warantee untill july. hope it works out for you.
SOURCE: Pilot Light will not remain lit
Try this, turn the black gas ****, on top of the control box, to the Pilot position. Set the temp. control on the front of the box to the desired temp. Then, hold a match or whatever else you use to light it, next to the end of the pilot, then, while holding the match to the pilot, press the reset button on top. When the pilot lights, continue to hold the reset button down for about 1 minute. Then, after a minute, turn the gas **** to the ON position, then it should remain on.
SOURCE: gas water heater kenmore model pilot will not stay lite
I have the same problem. Water heater operates on a very simple principle. of thermo-mechanical feed-back and response. In my case, I have a Kenmore Power Miser 6, NG heater with an electronic pilot ignition system. The heater is just over one year old and last month (conveniently just after the 12 month service warranty expired) the pilot light started extinguishing on a very regular basis. I find it interesting that the very problem I am experiencing, is happening to other Kenmore owners (victims). The solution can be found in replacing one of two possible components; the pilot assembly or the gas valve manifold. The price of DIY pilot assembly replacement is approx. $60 . The valve component is significantly higher. Water heaters are designed and built to provide years of trouble-free reliable service. This is the first Kenmore product I have owned. From a customer perspective, with regard to product performance, Sears/Kenmore needs to take a strong look at their supplier quality. Oh, by the way, contacting Sears for remedial relief only managed to frustrate and infuriate me. You see, I am in Quality for a world-class aircraft company. I understand what ethical steps are required to satisfy a valued customer. I plan on ripping out the defective unit this weekend and replacing it with a reliable Home depot special. At least with HD, if the heater fails to perform , I can return it. Hey Sears in Chicago, don't come crying to the consumer when you are looking for the trendy "bail out". Signed- "Burned Out" in La Habra, California.
SOURCE: no hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
SOURCE: i have a richmond gas hot water heater model
resetting your lock out for richmond power vent
The pilot light jet may have got a little bit of dirt or grit in it which is preventing it from keeping alight. Try probing the jet with a fine piece of wire to see it the blockage can be dislodged. You may have to unscrew the jet to clear it by blowing air through it. Make sure gas is turned off first before removing any parts.
The pilot light also has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. If, after cleaning, the pilot light keeps going out, it would seem that your thermocouple is faulty and needs to be replaced
