Question about Home
Strick plate on grandfather wall penduluem clock quit chiming and THUDS the time instead how do i fix it
5 Related Answers
jdthefixer
  • 746 Answers
SOURCE: Elgin grandfather clock chimes not working
I'm not positive about this, but I seem to recall that these type of clocks have two "silence levers" on the movement. These levers are located at the upper left and upper right corners of the movement as you face the movement from the back. The movement back panel has to be removed if it has one.
If the levers are pushed toward the chime rods, they will silence the hour or musical chime, depending on which one it is. I believe the silence levers are supposed to be moved away from the chime rods so the rods can retract and then strike the chime bars.
Posted on Mar 29, 2009
John McCaffrey
SOURCE: Problems with Howard Miller dual chime dual west and Beeth movement clock
If you manually set the time, the chimes will be off unless you wait for the chiming to finish before continuing to turn the hands.
Press the TEST button to get the correct number of chimes in synch with the actual time.
Posted on Jul 03, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Strausbourg Manor Wall Clock chime adjustment
It is normal for the average wall clock. Of course, this can be adjusted, but without watch/clockmaking knowledge it is impossible, because first you need to find out which part of the movement is causing early chiming - and there are plenty of them.
Super fine adjustment can be found only in top of the range clocks. Hundreds of hours of craftsmenship are spent to adjust and fine tune them. That's why they cost a fortune.
If you can not live with that early chiming, you have to bring your clock down to the watch/clock repair shop and ask for help. Be ready to pay quite a money, as this job takes the skill and a lot of time.
Rate me, please.
Posted on Jul 29, 2009
Anonymous
  • 15 Answers
SOURCE: the time and chimes are out of sync for our tempus
Turn the minute hand until the 16 westminster chime operate and then the hour strikes. Remove the minute hand and simple put it back on at the 12 o-clock position. The chimes should now be in sync.
Fred
Posted on May 10, 2010
JohnB
  • 25 Answers
SOURCE: Quartz president wall clock, I need to set the chime
I have a pendulum wall clock from the president collection. If yours is the same or similar, the following may help:
*Look at the back for a slide switch labled "start" at the top and "set" at the bottom and move it to "set"
*Look for for small push buttons. They represent the hours and minutes. Push each in turn, the number of pushes to represent the time, ie, for 09:45, ignore the first(0), push the second 9 times(9)-push the third 4 times(4)- push the 4th 5 times(5). When done, push the slide switch back to "start".
If yours is the same as mine - a wall hung pendulum clock with Westminster chimes, made around 1988. I would be happy to scan and send a copy of the instructions.
John
Posted on Nov 03, 2010
Gazo Rancho Santa Fe Grandfather Clock won't chim
Check the wires in the back.some times the get corrodes.
Dec 17, 2014 | Home
Halo Grandfather Clock won't chime hour
In my eyes there are two kinds, ones that are a real grandfather clock that runs on gravity using a series of weights and gears with different counterweights for chimes and running the clock itself, and there are the show pieces that look like a grandfather clock but run on newer tech and electronics. If a real one then would try first pulling the weights to the top. They are usually shaped into a pinecone or something. If weight is at bottom them have to pull corresponding chain with weight till the weight is at the top of case. As "time" goes by the weights lower. You should have different counterweights for the clock, chimes, dancing figures and whatever else it may have. All the weights move at different "speeds" so you have to keep an eye on them to make sure it keeps correct time. I would recommend consulting the manufacturer if possible. There are so many kinds out there is really hard to tell by such a short video.
Dec 16, 2014 | Home
I have a Coaster Grandfather Clock. I lost the manual. I need to find out how to reset the chimes.
Hi Wanda....call Coaster Furniture national call center -
1 877 221 9666. They can tell you how to reset the
chimes. Ask them for a manual.
Regards,
Dennis
Oct 21, 2014 | Coaster Furniture Large Traditional...
How to adjust Grandfather clock that chimes one chime less ?
Move the hour hand counter clock wise to 10 o'clock. Then turn the minute hand clock wise to set the correct time.
Main Page
Oct 04, 2014 | Home
How to reset a chime clock
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Jul 10, 2014 | Home
Edward Meyer 31 Day Grandfather Clock manual
I recently bought an Edward Meyer clock from Grandfather clocks for less. The clock is beautiful, but it never chimed. I even took it apart and repaired the chimes, the hammers were too far away from the chiming rods, but now that it does chime, it sounds like someone banging pots and pans together, it's horrible. I've been looking online to find replacement chime and hammer parts so I can fix it myself.
Jan 23, 2012 | Watches
Home Logo
73 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
