Question about Zephyr Kitchen Ranges
Is there a reset button for a Zephyr hood? I had to remove clean and replace a light fitting to replace the bulb. When I put the fitting back in the wire was loose so it shorted out the whole hood.
Posted by Matt Hennessy on
5 Related Answers
Anonymous
  • 171 Answers
SOURCE: Zephyr Milano hood fan and lights stop working. Power is on.
Hi ronio,
I'm Harvey the Master Plumber.
Your problem is: After the power went out your Zephyr hood lights and fan don't work at all. There is a faint glow on the digital display but the fan and lights don't respond to pressing the control buttons.
First check the circuit breaker. If OK then check the transformer in the unit. It's next to the fan motor. If no power on the high side then you have a loose or broken connection. If you have no power on the low side the you have a bad transformer. If OK then you have a bad control board.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 27, 2008
Anonymous
SOURCE: light blub burnt out
The easiest way to remove the light bulb is to wear a rubber glove, use your palm to press against the bulb, and turn counter-clockwise.
The suction created by the rubber glove should allow you to remove the light bulb easily.
Posted on Jan 15, 2009
Anonymous
SOURCE: Phill and Ted pram hood hard to put back in place
I have the same problem with a Phil and Ted's Sport - but I believe I have the solution as below. This is taken straight from the Instruction Manual which you can view at: http://www.arango-design.com/Phil-Teds-Sport-Buggy-p/7890-0001.htm - towards bottom of page is a link to the instruction manual - which I was unable to get on the Phil and Teds website. Got this today but haven't tried it yet. Hope this helps.
Really becomes clear when you see the pictures in the instruction manual.
Regards, John
Hood
The sport hood is packed disconnected.
To reconnect:
1. Locate sun hood and hold it facing down, as shown ‘a’.
2. Insert crimped wire ends into frame, through eyelets, ‘b’.
3. Lay hood back (to top of buggy).
4. Locate red coloured pocket at top of fabric seat and insert rear hood wires into each side, ‘c’ and ‘d’.
5.Open hood and attach domes, at bottom of hood, to main seat, ‘e’.
6. Pull eyelet at top of hood over pegs on each side of frame, ‘f’
Note that the windows in the hood are lined with a sun mesh of
a lower shade factor than buggy fabric. Always use sun cream
and clothing for protection of children in direct sunlight.
Posted on Jan 29, 2009
mattylarocha
SOURCE: How do I remove a headlight bulb on a 2006 Lincoln
remove 2 10mm bolts attaching top of headlight to the radiator support.
remove plastic clip attachinig headlight to top/front of fender.
remove 5 phillips screws on top of grill.
carefully pull out grill enough to remove 1 10mm bolt attaching headlight to radiator support and use slotted screwdriver or prybar to seperate headlight tab from the bracket that goes under the bumper cover.
with a little effort and wiggling pull out headlight assembly.
Posted on Apr 17, 2010
Anonymous
SOURCE: replace fan/light switch zephyr pyramid range hood
I am also looking for instructions for PLHV36W6CC.
The fan is on right now but the switch is sliding back and forth loosely.
I just downloaded the manual but that was no help.
If someone has a quick solution, that would be great.
Please email me at [email protected]
I have stuck my hand up and fiddled around but besides just ripping it out, could use some help.
Thanks,
Robert
www.150FastGroup.com
Posted on Aug 03, 2010
I have a Zephyr range hood with GU10 bulbs. Easy to remove , unable to re-install. I'm the 3rd person on this journey.
The two small pins on the bottom of the bulb must line up with the small holes in the base of the socket. This can be tricky since you can't see it once the bulb is inserted. Make sure their nothing already in one of the socket pin holes (like part of the old bulb) and the note the socket hole locations and (lightly, using your finger tips) fit the bulb up into the socket and wiggle it until the pins and holes align. It does fit, but sometimes it is not without a challenge.
1helpful
2answers
How do i change a bulb on a zephyr verona range hood
I could not turn the bulb, and the rubber glove approach did not work. I unscrewed and removed the middle cover, which meant I could easily reach inside and turn the whole light bulb fixture.
12helpful
3answers
How do I remove burned out light bulbs from zephyr range hood? What do I replace them with?
What model range hood do you have? To remove most of the bulbs from a Zephyr hood, wait for the bulb to cool after use. Then rotate the bulb counter-clockwise about 60 degrees (less than a quarter turn) and the bulb should drop down. If you have problems turning the bulb, try the glass suction cup that comes with the hood or a rubber/latex glove grip. Sometimes a rubber jar grip will also work.
The one way to find out your range hood bulb may be to remove one and look at the side/back. The bulbs are labeled. Otherwise, check your manual. Zephyr has the manuals for most of their ranges here: http://zephyronline.com/customer_support . Use the drop-down menu to select your model.
Different hoods use different bulbs. For AK6500, 6536, 6542 Cyclone hoods, purchase type: 4OR 14 mini flood light bulbs. For the AK2500, 2536 hoods, you need to purchase type GU 10 halogen bulbs. For the Anzio models, including the ZAN-E30AS, get a GU-10 50W halogen bulb.
I hope this helps.
2helpful
How to for bulb removal and replacement on zephyr stove hood
Turn bulb counter clockwise about a third of a turn and then pull down. Sometimes dishwashing gloves make it easier to grab the bulb.
1helpful
2answers
How do you change the bulb on Zephyr AK2100S ?
To replace the bulb you need to use a suction cup to grab the bulb then turn counter clock wise.
If you need the manual it is on the link below. Page 18
http://www.zephyronline.com/docs/brand_essentials/products/manuals/typhoona_manual.pdf
Good Luck and please rate 4 thumbs up for the free answer.
My Zephyr hood model zto-m79s lights don't work. The unit was installed in 2007. Sometimes they sputter, flashing briefly, then nothing. Do I need a service call or can I fix it myself? Nancy
Try taking out the bulbs and wiping with a clean dry cloth. Sometimes when bulbs get hot the connection loosens, when you screw them back in do not over tighten.
Can I replace the light bulbs without removing the whole panel ?
Yes, it is possible to replace the light bulbs without removing the panel that surrounds the two bulbs. The problem is that those bulbs get slippery because of cooking oil splatters.
I recommend that you use a paper towel and some window cleaner (aka: Windex) Spray the towel and clean the bulb. Let each dry and turn the bulb to loosen it out. Use the moist paper towel to help turn is needed. Be so careful to not break the bulb as you remove it. Good Luck!
1helpful
How do I change light bulbs on a Zephyr Milano hood?
Hi elenara, try applying slight upward pressure as you turn the bulb. Remember righty tighty, lefty loosy. This worked for us, now if I could only find a replacement bulb. Good luck!
3helpful
Light blub burnt out
2answers
Bulb
Use a large ammount of bluetack on the glass - and wear leather gloves for safety.
Look closely at the replacement bulb to check the type of fitting.
Halogens with point pins pull straight out. Thicker mushroom pins turn anticlockwise before dropping out.
Edison screws obviously unscrew anticlockwise.
If the above method fails for straight pin versions, wrap string around the body of bulb and pull out using string.
Hope this helps
Kitchen Ranges Logo
Top Zephyr Kitchen Ranges Experts
Dale Copeland
Dale Copeland
john h
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
