The issue you are experiencing with your Olympus all-weather 700 camera, where lines appear across the screen when attempting to take a photo, could be related to a problem with the camera's sensor or image processing.
Here are a few things you can try to troubleshoot the problem:
If the above steps do not resolve the issue, it may be best to contact Olympus customer support for further assistance. They will be able to diagnose and fix the issue or tell you if a repair is needed.
It's important to note that the Olympus all-weather 700 is an older model camera, which makes it harder to find replacement parts and professional repair services.
SOURCE: line across middel of screen
Call 800-726-4405 for technical support and customer service - try to get your television replace
SOURCE: lines flashing across screen when I try to play a game
Most likely you have a faulty connection. Try wiggling the wire. If it effects the image, replace it.
SOURCE: i would like a manual for my digital camera
http://www.retrevo.com/s/Olympus-700-Digital-Cameras-review-manual/id/203ci155/t/1-2/
You can find it there, please download the pdf reader here www.adobe.com if you want to read and print the manual, Thanks and rate
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: HORIZONAL LINES FLASHING ACROSS SCREEN
lens is damage at this time but it still work normally... contact your technical to fix it...
