Question about Freezers
SOURCE: kenmore chest freezer power problem
Try to unplug the the unit power supply to reset the error. But if the error persist you have to call for a qualified technician,
Posted on Dec 28, 2007
SOURCE: Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Posted on Feb 19, 2008
SOURCE: Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Posted on Apr 23, 2008
Jun 09, 2016 | Electrolux Frigidaire 14.8 cu. ft. Chest...
Nov 22, 2015 | Freezers
Oct 08, 2015 | Freezers
Jun 26, 2014 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
May 28, 2014 | Zanussi 10.31 cu. ft. / 292 liter Chest...
May 08, 2012 | Magic Chef 5 cu. ft. / 142 liter Chest...
Sep 13, 2011 | Magic Chef Chest Freezer MCCF5WBX
Aug 07, 2010 | Kenmore 4.8 cu. ft. / 136 liter Chest...
Apr 02, 2010 | Bosch 8.72 cu. ft. / 247 liter Chest...
Apr 06, 2008 | Whirlpool 21.6 cu. ft. / 612 liter Chest...
333 people viewed this question
