Question about Mercury Boating
I want to remove the final drive from amariner 15 outboard but the sharft won's wont come away.
On my Mariner 15hp outboard motor i need to removue the botom part of the leg to work on the water pump for some reason the sharf will not come away.
Posted by Noel Kinbacher on
2 Related Answers
thomasnee
  • 677 Answers
SOURCE: replace water pump impellor 15hp yamaha outboard
Put the motor in neutral.On the leg of the motor there is a little side cover plate.Remove.Undo the bolts.This is the gear change linkage.At the cavitation plate,there is 4 bolts.Remove.If the lower housing does not drop,give it a soft whack with a soft hammer.When dropped,you will see the prop shaft and the gear linkage.Lower it all the way out.Its easy to work on if you put the lower skeg in a vice.Take the water pump apart BUT!!! have a look at which way the impellar blades are pointed.Grease the new impellar as you put it back in and turn it at the same time to get the nodes in properly.Heaps of grease to protect all the bolts.Makes it easier next time.Hope this helps
Posted on Nov 16, 2009
Testimonial: "cheers much appreciated "
Anonymous
SOURCE: how to replace water pump on a 1985 90 hp mariner
water pump replace
Posted on Mar 30, 2011
How to remove the twist grip on 15hp evinrude outboard motor?
Fix Tiller Handle on 15hp Evinrude - YouTube
? 2:02
www.youtube.com/watch?v=dl0b7WFKsjc
Mar 30, 2011 - Uploaded by Budnipper82 Evinrude 15 HP gear removal - Duration: 9:11. by kodibass 7,404 views. 9:11. Repairing an Evinrude 9.9 ..
Nov 01, 2015 | Boating
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Jun 25, 2015 | Mercury Marine 15hp & 20hp 4 Stroke...
Ob187506
I see it as a 6M from 1986 in the mercury listings...
Jul 27, 2014 | Mercury Marine 15hp & 20hp 4 Stroke...
648c 345747
forums.iboats.com/...mariner-outboards/363954-mariner-serial-number-...
Jun 13, 2014 | Boating
15hp mariner only firing on one cylinder
Check the ignition wires or spark plugs.
Check compression on each cylinder.
Jan 16, 2013 | Light Outboard Motor Boat Bass Fishing...
91 mariner 15hp. Runs but the cooling water trickles but does not shoot out
First easy check is to get some line trimmer cord(about 6 inches long) and with the motor running push it in and out of the water telltail hole.Sometimes this will unclog some debris.Hope this helps
Jul 09, 2010 | Light Outboard Motor Boat Bass Fishing...
15hp mariner only idels with the choke out
Hello! Draining the tank was a necessary move. You will need to remove carburetor, take it apart and clean it. It is a an easy job; they are quite simple. All you will need is a new gasket and you can make one. If the fuel filter is inside the gas tank, take it out and clean. If it's an inline filter you can replace it with an ordinary lawnmower inline. Use a carburetor cleaning solution. When you reassemble, lube the choke so it moves freely. Also clean the gas line.
Dry all spark generation parts. A hair dryer works well.
If you require more assistance don't hesitate to send a comment.
Guru......................saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Dec 20, 2009 | Raymarine Linear Feedback Unit For...
Boating Logo
152 people viewed this question
Top Mercury Boating Experts
Mike
ray gallant
john h
Are you a Mercury Boating Expert? Answer questions, earn points and help others
