SOURCE: HELP PLEASE
you should be able to use the control panel on the set, sometimes it's a little tricky, but if you keep trying you will get the right settings
SOURCE: Quasar model VV2008 tv/vcr
in side the mother board(kit) there should be vertical IC gone. check the vertical section for the IC number and replace it , this will solve ur problem
thanks
SOURCE: I have an old sanyo vwm 710 vcr. I have a new
Have you tried pressing the INPUT button on the remote; try pressing it up to 3 different times because I believe it sequences 2 or 3 times. With mine, hooked up to my RCA TV, 1st push puts it in Line1 on a blank blue screen, 2nd push shows Line 2 on a blank blue screen, and 3rd push brings it back to my TV with my satellite picture showing.
Sincerely, Rick
SOURCE: how to change vcr input from channel 4 to channel 3
On the Zenith, turn the power off. Hold down the Channel up or down button on the machine itself (not the remote) for 5 seconds, it will say RF03 hold down until it says RF04.
SOURCE: TV changes from input setting to channel 3 when turned on.
you need a service repair, on that ckt there's an IC function as memory IC replace that part and all your program well be stored. can found that ic most likely near switch botton area 4 or 8 pin IC.
