Question about Smeg Kitchen Ranges
My SMEG gas oven won't stay alight. When I stop pressing the oven regulator the gas goes out.
Posted by James Clarke on
  • John Papendick Nov 17, 2018
    It sounds like the thermocouple is either faulty, in need of a clean or needs adjusting.
Peter Taylor
    Habit-Forming:
    New Friend:
  • 119 Answers
Check the regulator at your gas bottles may need replacing
Posted on Nov 18, 2018
1 Related Answer
tunde007
Tunde Autos
  • 2382 Answers
SOURCE: My SMEG oven won't stay
Hi, it is your thermocouple. It's worth having a look first prior to getting someone to replace it though. You will see a small "probe" that sits in the flame which is the thermocouple, this is the fail safe device that cuts off the gas should the flame go out. When it heats up it keeps the gas on but when it cools (when the flame goes out) it will not let any gas through unless you have the knob held in. Three checks:
  • look at the end of the probe and see if it's sitting in the flame, it may have been knocked to one side during use or cleaning which will prevent it working - gently push it back into place and try again.
  • Has the probe become covered in grease etc which is preventing it working properly - clean with a rag and try again.
  • Is the end of the probe heavily corroded - if so will need replacing.
  • Sometimes they just get tired so will require slightly longer to warm up and hold. When you light the stove hold the knob in for 15 seconds and see if it holds then.
If none of the above work get a gas safe chappie round and put you a new one in.
Posted on Dec 22, 2010
Westinghouse oven LPG 527 wont stay alight and grill wont start
Normally the grill is completely separate to the oven. Press the ignitor before you turn on the grill, as, to ignite, oxygen needs to be present (ie: not flooded with gas) . and you should be able to see the spark from the ignitor in the grill. if you can't, then you may have problems with your ignition pack or ignition leads.
Feb 16, 2012 | Ovens
Smeg gas hobs ignite immediately but flame goes out when i let go of the igniter. I have to hold it down for a very long time befor it stays alight. this is time consuming and not right. What is the...
depending on what you mean by " a very long time " -- holding down the gas valve button while the thermo-coupling gets up to the proper temperature is normal. ( normal hold and wait time should be between 10 to 25 seconds, anything longer than that is a sign that the thermo-coupling is bad ).
c...
Jan 02, 2011 | Microwave Ovens
Why will my oven not stay alight when the knob is released
these have a sensor that detects the flame of the oven when you relese the button if it sences no heat it stops the gas.
Feb 07, 2010 | New World Spirit 110 (Gas) Kitchen Range
Kitchen Ranges Logo
582 people viewed this question
Top Smeg Kitchen Ranges Experts
Michael Thomas
Michael Thomas
Lee Hodgson
Lee Hodgson
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
