Question about Apple iPhone Smartphone
I have an iphone but i forgot the passcode and the phone got disa
It is disabled and i forgot the number to the phone
Posted by sparky00751 on
Michael Lei
    Master:
  • Apple Master
  • 498 Answers
With regard to this situation, you have to reset the passcode to unlock your iPhone. Just refer to below instruction to do that.
How to unlock iPad without password using iTunes
  • 1. Connect iPad to the computer you have synced with.
  • 2. Open iTunes on your computer and connect it with your iPad. If fortunate, you can enter the iTunes without password. But in most cases, there would be prompt asking for a pass code. Try another computer you've synced with, or use recovery mode. (The recovery mode will be mentioned in method three.)
  • 3. Find your iPad in summary and make a manual backup. Once the backup have finished, click Restore your iPad with the most relevant back-up.
For more details, check: How to Unlock iPad?
Posted on Jul 10, 2019
5 Related Answers
Tushar Khandelwal
  • 20 Answers
SOURCE: I forgot my passcode to unlock my iphone
It depends on the severity and the settings you have given the iPhone and whether you have the computer that you synced your iPhone with... Here's the full explanation. I would recommend reading the second paragraph first, but the solution if you really forgot your password is in the first paragraph.
==If you have the computer you synced your iPhone with==
If you cannot remember the passcode, you will need to restore your device on the computer that was used to originally sync the iPhone or iPod touch so that you can reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced to the iPhone or iPod touch, you will be able to unlock the device for use and remove the passcode but your data will not be present. Refer to "Updating and restoring iPhone and iPod touch software."
"If you enter the wrong passcode too many times, you'll see a message that says "iPhone is disabled" and to try again later. If you repeatedly enter the wrong passcode, iPhone or iPod touch will be disabled for longer intervals, before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect to the computer you normally sync with. Note that starting with iPhone 2.1 software, there is a setting to cause the device to erase itself after 10 consecutive incorrect password attempts. This setting is off by default. It  can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode."
The full article can be found here: http://support.apple.com/kb/HT1212
==If you don't have the computer you synced your iPhone with==
If you don't have the original computer the iPhone synced with, the only solution is to force your iPod Touch into recovery mode and then restore it. You will lost all the data on the iPod Touch, but after this method is done, everything will work. You can find the steps to solving this problem here:
http://support.apple.com/kb/HT1808?viewlocale=en_US
Posted on Feb 13, 2009
Steve L
  • 85 Answers
SOURCE: iphone disabled to "connect to itunes" but needs passcode
Turn your phone off and plug it into your computer holding the home button down. That will put your phone into restore mode.
http://www.mobileease.co.uk
Posted on Jul 26, 2009
whatcity225
whatcity225
  • 81 Answers
SOURCE: Iphone disabled, can't connect to itunes
You will need to do a reset. Hold the middle button(home key) while you plug it into the compter. Keep holding it until iTunes displays it found a phone in "recovery mode". You should then be able to do a restore.
Posted on Aug 30, 2009
Anonymous
SOURCE: i forgot my passcode and now my iphone is disabled.....
how do i find out what my passcode is
Posted on Sep 11, 2009
prioritycont
  • 41 Answers
SOURCE: I accidently enabled the voiceover on by IPhone
If you have your phone synced with itunes you can hook your phone to your computer by opening itunes on your computer and connecting your phone. Then click on your IPhone when it appears in the column on the left. Choose the option to restore to last backup or reset to factory defaults.
Hope this helps
Posted on Aug 20, 2010
I forgot my phone lock number for my phone and when I switch on my phone is just asking me to enter phone lock number and I forgot it
  • 1 Enter the default code of your cell phone and press the "OK" option. Most default codes will be "1234," "0000," the last four digits of your cell phone number, or Social Security number.
  • 2 Press the pound key on your cell phone's keypad. Enter a six-digit security code. The code is most likely "000000."
  • 3 Call your cell phone provider and ask them to reset your pass code. This will either reset your password to the default pass code or will disable the pass code option all together. Disabling the pass code will allow you to choose a new code.
  • Read more : http://www.ehow.com/how_7481065_unlock-phone-forgot-code.html
    Dec 09, 2014 | Cell Phones
    Trying to get my facebook friends and page back help.
    I disabled my Facebook account for a few years. Logging on with the same credentials (email address and password) you had before should automatically reactivate the same account.
    If you know the email address but forgot your password, you might still be able to use the password recovery options (I think the link says "forgot my password" or something similar). I haven't tried it to confirm. It should ask for the phone number or email associated with the account. Hopefully you have some of that info.
    If neither of those options work, you will likely need to email [email protected] send a polite email with as much information as possible with your request.
    If you didn't disable your account and Facebook did, you will probably need to email [email protected] instead.
    I hope this helps.
    Nov 25, 2014 | Computers & Internet
    Disabled forgot passcode
    Have to download 3rd party software from internet to disable unlock code... google it and u will find an abundance of these progs... Goodluck and post results please
    Dec 30, 2013 | ifrogz iPhone3gstrb Soft Touch for iPhone...
    My phone is not working, it says the service disabled. How I can fix it? I think if I have the entry code I can do it. My phone number is 8122438772 serial number is 268435459307377843
    If you forgot the password or don't know the security code, You have to master reset the phone. Contact your service provider to get a master reset code at free of cost....You can also visit http://www.unlock-zone.com/ and can see different options there to get unlock code for a price. Choose any price appropriate for you.........
    Dec 27, 2010 | Cell Phones
    Disable Sim Lock on Samsung valencia. I forgot the PIN Code. so i can not Disable SIM LOCK on my phnoe.
    you can unlock your phone here http://www.theunlockspot.com/samsung/rs10wp8/
    They will provide the code when you enter your imei number,you just need to select your phone model and network provider
    Dec 20, 2010 | Samsung Star GT-S5233 Cell Phone
    I forgot my mtn share N sell pin
    i forgot my mtn share n sell pin. and my line was block for share n sell
    Apr 27, 2009 | Teac (DV-W58GA-PUK) Burner
    I forgot the lock code of my cellphone
    You can go to your carriers store and they wil unlock your SIM card from their network. It would SIM locked. Card disabled. A ech from your carrier will unlock it from their network.
    Apr 16, 2008 | Nokia 6680 Cellular Phone
    Apple iPhone Smartphone Logo
    Top Apple Cell Phones Experts
    Ekse
    Marvin
    Marvin
    sandyp4ever
    sandyp4ever
    Level 1 Expert
    Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
