Question about Optics
Help with sighting n a Barnett 4×32 multi reptile scope
Posted by Tim Meadows on
4 Related Answers
Anonymous
  • 8 Answers
SOURCE: Sighting in my scope
That should be covered in your manual.
If not, give Nikon a call.
Or, repost your question on a Bulletin Borad such as at SWFA, where another user may have the identical scope.
Posted on Nov 26, 2008
Anonymous
  • 63 Answers
SOURCE: scope won't sight in
Yes, rim fire scopes can't be used on a stronger firearm as the recoil will alter the internal mechanism. I fought with scopes of all types for years until I bought a used Leopold, never finding a better one! Hope you can find one of those.
Posted on Jan 05, 2009
Leonard Zook
  • 243 Answers
SOURCE: 1. HOW TO READ SCALING OF SCOPE.? 2. What is
You have not provided enough information for us to help you. What type of rifle? What do you mean by scaling?
With the scope on 3 power you should be able to sight it in at 25 meters. Going to a higher magnification may cause blurring at that distance.
You also may have mounting problems that are causing the scope to move around when you shoot. Your rifle may be fine.
Posted on Oct 14, 2010
John Fourteen Six
  • 2418 Answers
SOURCE: I have an EXCAVATOR 8-32x50
Well, my first thought is that with standard 5.56 and a 16" barrel, you're only going to experience about 1"-1.5" drop at 100 yards, at 50 yards it's more like 0.2" drop. You may have been over-compensating for the anticipated bullet drop.
When zeroing a scope, you want to keep in mind that the scope is a fair distance above the center of the bore on an AR... anywhere from 1" to 3" or 4" depending on your rig. At 25 yards, zeroed, your scope is going to be aiming LOW at 50 yards, rather than high and it will be aiming VERY low at 100 yds on a 25 yd zero.
My advice would be to find out how to calculate scope offset based on how far above the bore your scope is mounted and use that information to adjust your scope to 50 or 100 yds after you re-zero it at 25 yds. You should be able to have your rifle dialed in at 100 yds using as few as 3 shots, but no more than 9 shots.
Here's what I do and it works well for me.
1 shot at 25... adjust accordingly to zero the scope to 25 yds (confirmation shots as needed to check scope adjustments), crunch your numbers to figure out how many clicks you need to go UP with your scope to adjust the zero from 25 to 50 yds, fire and check your 50 yd target... adjust accordingly to zero to 50 yds, crunch numbers, adjust scope up to zero at 100 yds, fire. Your rifle SHOULD be zeroed at 100 yds now.
Also, very close range + scope = bad.
Iron sights or red dots are good for close range. Scopes with more than 4x magnification are relatively useless for short range unless you plan to miss.
Posted on Jun 15, 2011
Instructions to mount scope
PDF]OWNER'S MANUAL - Crosman
www.crosman.com/pdf/manuals/M4-177-515.pdf
Translate this page There are two different rear sight options for the M4-177 depending on which model you purchase.) Option 1- ... the airgun in any way inconsistent with this manual may make your ... Adjust the rings on your scope to match the measurements of the top rail. ... Toattach the sling at both ends push the sewn webbing loop end.
Crosman M4-177 Multi-pump .177 Pellet Air Rifle Table Top ...
? 24:29
https://www.youtube.com/watch?v=s_0grKCOmX0
May 18, 2012 - Uploaded by Replica Airguns
ReplicaAirguns.com - Crosman M4-177 Pellet-BB Multi-pump Air Rifle ... -Single shot - bolt action with manual advance magazine.... I particularly like the removable iron sights and full rail formounting a scope or red dot sight.
Crosman M4-177: Installing and Adjusting the Sights ...
? 8:38
https://www.youtube.com/watch?v=x8XKOmb41QA
Aug 28, 2012 - Uploaded by Crosman
A detailed look at installing and adjusting the sights for the M4-177 and sighting ... Crosman MK-177 Pellet-BB Multi-pump Air Rifle Table Top ...
Crosman M4-177 shooting rev
Dec 20, 2015 | Crosman M4-177 Air Rifle
How do you boresight a Barnett Red Dot 3 crossbow scope?
I use a 22 cal rifle laser on mine , the 22 is nearest the same diameter to the bolts I use so I can lay laser right into same bolt bed on frame that bolt normally rests in , then bench rest bow and get into shooting position then adj scope to bring crosshairs/ reddot onto laser dot at white target board , try to adj at distance you'd comfortably take a shot at
Sep 07, 2015 | Optics
The battery in my red dot scope from barnett has died what size battery is it?
take the battery out , look at that the battery says on it , type that up on google and find the type
Oct 03, 2013 | Optics
Cannot get to the bull's eye. rifle shoots 2" to right of bull's eye. after two full turns left on windage - nothing happened. I',m ready to return to the store. Any help???
continue to adjust the wind-age. If your problem persists I would suggest turning both to a random point and re-start sighting the gun. If that does not fix the problem return the sight because this most likely means the wind-age is disconnected.
Aug 17, 2010 | Bushnell .22 Rimfire 3-9x32 Rifle Scope...
Optics Logo
311 people viewed this question
Top Optics Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you an Optic Expert? Answer questions, earn points and help others
