Question about Panasonic KX-T7730 Corded Phone
Part no for extension card
Please I need the part number for extension card KX-TDA6174 meant for the system KX-TD600 Pbx
Posted by Olusina Bode-Adeoye on
Anonymous
  • 60 Answers
That is the part number.
Posted on Aug 04, 2009
How do i fix card obstacle error on Panasonic tde 200
Hello Fra,
Your tech support would be best to address this issue.
Nonetheless I am including 2 links that can help you.
Best of Luck,
JP
Panasonic KXTDE200 PURE IP PBX Manuals
Panasonic KX TDE200 Manuals
May 14, 2015 | Panasonic KX-TDE200 Converged IP-PBX...
Our company uses the PANASONIC KX-T7730 phone system, just wanting to know if customers can call directly to our extension numbers?
if your pbx has a built in disa feature, then you need to program
the DIL (sys. pgm. # 418) to DISA-OGM 1. Then you need to
record an OGM (program 9,1,1) to tell you customers that
they can dial the ext.# directly.
Oct 29, 2013 | Panasonic KX-T7730 Corded Phone
Hi , i have panasonic TDA100 ipbx system i recently buy kx-tda170 hybrid extension card and install to pbx how can create extension from 25aid cable
The 170 card is an 8-port DHLC and it's pinned exactly like the old 123211 and the TD series systems where the first 2 pairs are the voice and data for a Panasonic Analog phone or a single line set on the first pair, and the 3rd pair is unused in the TDA. There are 8 3-pair sets in the cable and the 25th pair is nothing. Here's a link to an installation manual http://public.carl.airpost.net/Pana/TDA/100_TDA_IM_07-04.pdf The instructions start on page 139.
Carl
May 05, 2011 | Panasonic KX-T7731 Corded Phone
I am using Panasonic KX-T7730 i could not make out going calls wich strarts by " 0 " i change my phone but the problem is still there My extension number is 114 we are using pbx system
Is your extension programmed to allow dial 0 calls? The phone is just an instrument, it has no programming. Guess where the program is and who controls it? Yep, see your system administrator.
Carl
Apr 14, 2011 | Panasonic KX-T7730 Corded Phone
Is tha possible to get 25 single lines on 16SLC card(50 pin)
The 25-pair Amphenol connector is just something the industry uses because it's standard and easy. In a TDA system, the 8-port C.O. Trunk card uses the first 8 pairs, a 16-port the first 16 pairs, an 8-port Pana station card uses the first 24 pairs, 3 pairs per extension. The last pars don't have any hardware behind it and are connected to nothing.
The only phone system that I remember where all 25 pairs are used is a 1a2 10 button set and, maybe a Comdial system where the 25th pair is the common audible for station 17 :-)
Carl
May 22, 2009 | Panasonic KX-T7730 Corded Phone
Registration of ps in pbx
i have a problem in panasonic pbx TDA 620 which tells all extensions are buzy when hhave been called and the stat of the card nothing neither red nor green solve this problem for me please thanks as always for your help
Sep 16, 2008 | Panasonic (KX-TDA200)
Setting the time on the panasonic KX-T7630
This is a PBX system, correct? If so, the fastest way would be through the PBX control computer. If you have a Panasonic TAW series PBX, I really like the AbleComm websites, search for your model PBX there.
Dec 06, 2007 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
