Question about RCA RCR412C Remote Control
None my remote is not responding to my tv
Posted by thiem on
Anonymous
    Problem Solver:
  • 12 Answers
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Posted on Dec 15, 2007
Remote not working nor do side buttons respond.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 27, 2016 | LG 47LG50 47 in. LCD HDTV
LG 47lg50 white screen no buttons responding
A white screen with nothing else leads me to believe you have a problem with a t-con board or a signal board on that TV.
you can get parts for this tv at www.interliquidparts.com
Feb 24, 2012 | LG 47LG50 47 in. LCD HDTV
I have an old Zenith T.V. that works perfectly except that it can not be controlled by the brand new remote I bought. It appears that the T.V. does not respond to the remote. The remote has codes for...
If you have tried all the codes for the tv, and none of them work, the tv might be too old to respond to the newer remotes. Check that the batteries are inserted properly into the remote.
Some older tvs are just not compatible with todays systems.
May 27, 2011 | Televison & Video
TV Locked Input Password. Problem is no remote control so cannot unlock. Is there a way reset the TV. None of the buttons on TV are responding as TV is waiting for password.
You can try unplugging it for about an hour to let it reset itself, but I doubt that it will reset the password.
You must have remote control, I would get the original remote to get full functions.
What is the make and model of the TV?
Mar 12, 2011 | Televison & Video
None of Tv controls on side of tv will not work and remote will not work
MAY HAVE A STUCK BUTTON SUGGEST PRESSING EACH BUTTON HARD AND SEE IF ANYTHING CHANGES. THE MAIN MICRO PROCESSOR IN THE TV WILL RESPOND TO BUTTON COMMANDS BEFORE ALL ELSE SO IF THERE IS A STUCK BUTTON NO OTHER BUTTONS WILL WORK AND IT WILL NOT RESPOND TO THE REMOTE.
Dec 17, 2010 | LG 42LC2D 42 in. LCD HDTV
Remote sensor is not working
TRY GETTING A SKY REMOTE THEY ARE PRE-PROGRAMED TO ALL SONY TV'S
Nov 11, 2009 | Sony FD Trinitron WEGA KV-32FS320 32" TV
TV does not respond to remote commands,
I'm sure you've tried this, remote batteries is most common cause.
Make sure sensors on TV and remote are unobstructed(remote only works if line of sight to sensor is clear) and clean. Windex and Qtip. Damaged/dirty/defective remote, try different if possible (universal). If none of above works(99% chance), extreme longshot is TV circuitry.
Sep 26, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Remote contol will not work
http://www.directv.com/DTVAPP/global/contentPageIF.jsp?assetId=P4380052#h:1020.989
directv remotes are not guaranteed to work w/ all types of TV's. when programming remote to TV, make sure you are holding down MUTE and SELECT both at the same time for about 4-5 seconds. until it blinks twice at the top of the remote. also the slide switch must be under the "tv" mode on the right hand side. the website i provided is by directv, and has a list of their codes for the brand of tv that you have.
if you are trying to program a remote to a directv box, and none of the codes are working for the directv box, contact directv to have them send you a new remote.
Jan 22, 2009 | Directv D11 DTV Receiver
TV not reponding to remote
Remote IR LED receiver defective located on front edge of PC board.......I will get the part # for you........................T.
Feb 27, 2008 | Televison & Video
Nothing works on remote
Hi, check out my (admittedly lengthy) fix here:
http://www.fixya.com/support/t300197-tv_w_built_in_dvd
Hope it helps!
Ryan
Nov 21, 2007 | Mintek DTV-373-D 37 in. LCD HDTV
RCA RCR412C Remote Control Logo
52 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
