Question about La Crosse Measuring Tools & Sensors
How do I set outside temp, time zone, and time on la crosse modelw86111,sensor tx141v2
Posted by Louis Achimon on
Tom Chichester
    Top Expert:
  • La Crosse Master
  • 55,379 Answers
5 Related Answers
Anonymous
SOURCE: WS-1510-iT La Crosse Wireless Weather
My 1510-IT came with a faulty battery cover top for the rain guage. There should be a metallic clip mounted to the cover to tie the 2 batteries together electrically. Mine had nothing there. I soldered a wire between the 2 batteries and used some cardboard under the cover to make sure the batteries were pushed down into their holder. Problem solved!
I can't imagine this is systemic but it happened to me.
Posted on Sep 22, 2008
Anonymous
SOURCE: can't figure out how to set the time zone
I just pressed and held for about 3 to 5 seconds the button with the +/- on the bottom of the clock and until it showed the part of the US that I was in.
Posted on May 21, 2009
shadtremonky
gerald darling
  • 353 Answers
SOURCE: Optimum temperature setting for dual zone air conditioning
cooler up stairs
Posted on Jun 27, 2009
homedesigner
Mark Tidwell
  • 583 Answers
SOURCE: We have an atomic clock with calendar and
Press and hold the SET key for 5 seconds. Press set key repeatedly until TZ is displayed on the bottom. Use the "+" key to set the time zone. -8 is for Pacific Time Zone, it will display -8 PST in the display. Press set to go to the DST setting, and so on until you've cycled through the options.
Posted on Feb 20, 2010
BillB-SA
Bill Buchsbaum
  • 2761 Answers
SOURCE: I can't get my atomic wall clock to set on daylite La cross wall
The easiest way to reset it would be to change it to Eastern time - that will give you the correct Central DST.
Bill B
Posted on Mar 19, 2010
Received a gift from France: a La Crosse Technology weather sensor TX 29 with atomic clock. It's connected to Frankfurt, Germany therefore out of range and in Celsius. Any chance to modify settings?
Go to www.lacrossetechnology.com and see what you can find regarding model TX29. I have a LaCrosse 8005 right in front of me and it has a switch for F or C. You also can select your time zone.
May 28, 2018 | La Crosse Measuring Tools & Sensors
My outdoor temp is slowing almost 10 degrees warmer than actual temp outside. What is problem.
You are using a wireless system that transmits signals between the outdoor sensor and the indoor receiver. They are not a perfect match. You cannot make adjustments, thus if your lucky, the factory matched up the devices prior to the sale. You may contact Lacrosse for a replacement outdoor temperature device.
Jan 11, 2018 | La Crosse Measuring Tools & Sensors
I have a La Crosse W86111 and the outside temp blinks? It didn't do this when I first got it 2 months ago.
There may be defective batteries or a poor battery connection at the transmitting end.
Feb 12, 2017 | La Crosse Measuring Tools & Sensors
How to set time zones on La Crosse Projection clock 3N6
https://www.lacrossetechnology.com/support/manuals.php
3N6 its the technology named , but the model you can choose can be find on this site .
Mabe the model and page are find on these pictures.
la crosse 3n6 Google zoeken
Feb 18, 2016 | La Crosse Projection Alarm Clock with...
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
Dec 16, 2015 | Audio Players & Recorders
How to set a Model:WT-8005 atomic cllock
download the manual from here: http://www.manualslib.com/manual/533191/La-Crosse-Technology-Wt-8005u.html
Mar 16, 2015 | La Crosse Technology Black Model Wt-8005...
The sensor from my weather station is not registering outside temperature
I've had the same problem since I bought this unit 2+ years ago; when the outside temperature moves into the freezing zone, the sensor stops transmitting. I contacted Lacrosse-- all they could suggest was change the batteries. My solution: throw it in the trash!
Aug 05, 2012 | Bushnell Measuring Tools & Sensors
Can not set time zone
Press the triangle shaped button to set the correct time
zone. It will toggle the clock mode through the four available time zones in the Continental U.S. Above the seconds digits, the LCD display will indicate "P" for Pacific, "M" for Mountain, "C" for Central and "E" for Eastern.
Mar 01, 2011 | La Crosse Technology WT8005UB Atomic...
We have an atomic clock with calendar and temptature on it. We changed the battery and it is now on Eastern time zone, not Pacific time zone. How do we set it? It is La Crosse Technology Radio Model #...
Feb 20, 2010 | La Crosse Radio Controlled Atomic Clock
Measuring Tools & Sensors Logo
240 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
Marvin
Marvin
Ngoro
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
