Question about Mercury Boating
How to change leg oil in 2018 merc 400 varado?
Posted by Vince Giguere on
1 Related Answer
Lawrence Lewis
  • 65 Answers
SOURCE: What kind of fork oil should I use for a 2018 Ninja 400?
standard fork oil..
Posted on Oct 17, 2018
How do you reset the change oil light
You need to provide, the make, model and year for anyone to be able to answer this question
Aug 26, 2018 | Cars & Trucks
What is the oil capacity of each front fork leg?
200ml per leg. I run a little shy because it can give a hard ride. Use a good synthetic
May 10, 2014 | 1984 Honda GL 400
What is the correct oil for a 2004 Merceedes C200K differential? The manual says "refer to Mercedees Dealer" The Merc dealer will not disclose the oil to me, preferring they do the oil top up/change.
go to an auto spares shop and read the oil spec catalogue for your vehicle. Go to a fuel depot and ask them for the recommended oil specs. Read a owners hand book or go on line and type in recommended oil for merc diff c200K. Generally if it is an ordinary diff the an OEP 80/90 oil be ok and if it is a LSD diff then an OEP LSD oil will be ok. I am suspicious of a dealer that will not say what can be found out as general knowledge as they may be using any old oil but loading up the price claiming to be a special merc oil. I have found in business that to be helpful to people generally creates the opportunity to foster a business relationship and after all that is how I keep repeat customers.
Feb 20, 2014 | 1991 Mercedes-Benz 190
Change fork seals
you need to undo the pinch bolts on the yolks and remove the front wheel & mudguard. Undo the bolys retaining the brake caliper and swing it towards the frame downtube, secure it with string. Withdraw each fork leg and clean up with a soft rag. On each leg, remove the top bolt (slowly to release spring pressure) and pour out the fork oil and discard it. Pour in a small amount of parrafin and swill it around a bit to clean out any residue. Remove the dustcap or gaiter and put it on one side. You will now see the fork oil seal. If it has a circlip then remove it, if not, then don't bother. Prise out old seal carefully making sure not to mark the soft alloy of the lower leg or the chrome on the stantion. Rub a little fork oil onto the new seal and carefully slide it over the stantion, pushing it all the way down. Use a piece of wood to firmly push the seal into the lower leg until it sits squarely and fully into place. Replace circlip if necessary and refit dust cover. Refill each fork leg with 142 ml of 10 wieght fork oil and replace top bolt. pump the leg a few times to settle the oil and then refit the legs in the reverse order of removal. When done, pump the forks a few times, go for a cuppa whilst it settles and then you are all ready to go.
Jul 02, 2011 | 1981 Yamaha XS 400 Special
I just bought a 150 yamaha motor and i need to change the oil all i see is the oil level screw and can i use car oil 10.30 is their a oil filter thanx
Are you changing the leg oil? if so you will need a pump in order to do so. The top screw is a vent hole and the bottom on the leg is the add & drain hole. Pump the oil in the bottom of the leg until the oil starts to come out of the vent hole. Leg oil is 90w
Jul 25, 2009 | Boating
Fork and engine oil for kawasaki kle 400 from 1993
Get the fork oil from the Kawasaki dealer and he will give you the right oil and tell you how much is needed. The gearbox oil is 10w40, any major brand is fine. I think your bike has a oil dipstick? If not then the oil capacity should be on the casing by the oil fill. Worst case, ask the dealer while you are there!
Best wishes and I hope this helps.
Please rate this solution. Thanks Robert!
Apr 06, 2009 | 1993 kawasaki KLE 500
Boating Logo
145 people viewed this question
Top Mercury Boating Experts
Mike
ray gallant
john h
Are you a Mercury Boating Expert? Answer questions, earn points and help others
