Computers & Internet Logo
Question about NEC Computers & Internet
I have an NEC 12 TXD system, incoming calls do not ring on the main handset and only show on the line button briefly ?
I have done a full system restart, but the problem remains
4 Related Answers
Anonymous
  • 7 Answers
SOURCE: RCA 25450RE3 - Incoming Call Ringer Setting
try turning ringer speaker volume down. if that does not work, then remove battery for 10-15 minutes and replace and try again.
Posted on Oct 12, 2007
Anonymous
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
Anonymous
SOURCE: Cleer ID display on NEC Ranger DK824 telephone system
I have a DK824 I bought in 2000 which did not have called ID capability - that was explained to me on purchase - if yours is 2 years old they must have kept the models the same for a long time though
Posted on Mar 26, 2009
Marlowe Amoguis
  • 405 Answers
SOURCE: We have a 3Com NBX
hi . have you tried to check the phone control button located at the lower left portion or the built in acoustic chamber inside the phone that provides air pressure to maximize volume has been damaged.It has been 2 years already and have not check..This acoustic chamber helps to maximize the volume..Have you tried using the headset.If still headset doesn't work then there is a problem with acoustic chamber inside and it needs to be checked by the manufacturers or providers..
Posted on Jul 07, 2011
How to get incoming calls to two handsets
The system should be configured so that the desired lines, whether CO or extensions, are set to "Appear and Ring" on each set.
Config... Terminals&sets... Show Set... (enter #)... Find...Line Access... Line Assignments... Show Line (enter #)... set to "Appear and Ring" on each set that needs to ring.
You can also have a line "Ring Only" without an appearance (dedicated button), in which case it will show as an intercom call.
We have a Panasonic KX-T7433 telephone at work but 2 of the phones do not ring when we have a call we have to go and pick up the main phone at the other end of the room. We can call out on the phones but...
From the phone, press intercom and dial 790. That clears any "cleaning person" button presses. Check the ringer control button on the left side of the phone to make sure it's on. The "we can't pick up the call" is disturbing because the line should appear on your phone. In a TD system, the lines are normally numbered 01-12, but that's on this side of the pond. If you have ISDN ot EI trunks, they may be different. In a standard key system, the line buttons are called Single CO (SCO) buttons and are programmed by prressing Program 99 on an idle phone, then the button and reading them. If they don't say SCO 01 02 03 etc, you dial 0+01 02 03 etc STORE to change them.
Pick up the handset and drop it back down when you're finished.
Carl
3helpful
3answers
2helpful
2answers
DO not disturb feature will not turn off
do not pick up the headset
push feature 69 feature
21helpful
4answers
NEC Topaz Office Phone - How to program phone to call forward off premise
How can download user manul for this phone?
NEC IP2AT-6TXD TEL2(BLK)
6helpful
2answers
Uniden 5.8Ghz phone.
3answers
Model 28112ee2-4 dect 6.0
For the handset, you can use the menu button to check the HS Setup settings. For the answering machine, you may have pressed the side button that turns it off. It would say "off" on the lcd if you did that. According to the manual (I just bought one of these).
3helpful
Blinking light but no ring sound on incoming calls
This is a phone system phone and each station you want to ring when a certain phone line rings has to be programmed into the system. This is not something you can change at the phone itself. You will either need to pay a company to make programming changes or locate a programming and installation manual for your phone system (not the phone) and try to re-program it yourself. If you have not done this before it will not be easy but it may be worth the effort so you can continue to make your own changes instead of paying someone $200 per hour to do it for you.
There is also the remote possibility your phone's ringer is broken. You can try swapping your phone with another of the same type and model to see if it will ring.
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
David Shaub
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
