Make sure the feed dogs have not been dropped, ie for darning or free motion quilting. Also, make sure the stitch length is set high enough to actually create a forward stitch.
try another bobbin, that one might be warped
use a can of computer air in the bobbin area for lint
if the problem persists then the machine should be checked
You have to take off the cap to the screw on the side of the cover. It is just bellow the foot tension. and then unscrew the side. It will then come right off, you may have to tug a little. Then, you can take the bulb out and replace it.
A sewing machine and an overlocker are two completly different things, but a sewing machine is usually able to do a cover stitch. An overlocker will cut the fabric at the same time, a sewing machine cannot do this.
some machine are self oiling, when they are run & they parts get warm to hot then the oil come out of the parts & it's self oil.
contact a janome dealer & ask if your model is self oiling
On my machines, the one step button hole requires a pull down sensor that the button hole foot triggers when it has done one side. You put the button in the holder part of the button hole foot, set up with sensor and start to sew, being careful not to touch the trigger, then the machine will sew the required length, change stitch and then do other side. Maybe there's a demo on you tube ? I hope this helps
