Go to the Manufacturer of the universal remote. Search for the model of the remote, printed usually inside the battery cover or battery holder. Look for the owners manual, and it has instruction based ojn the TV make nad model It will have a set of codes to try and h0w to assign them in the manual of the remote.
https://www.quora.com/How-can-I-find-the-exact-code-of-my-TV-to-use-on-a-universal-remote-control
https://www.youtube.com/watch?v=pBXKBgFMYNg
SOURCE: Universal Remote Codes
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press the CHANNEL DOWN button to backtrack through the library until the device changes channel. Pressing CHANNEL UP changes the direction to forward again.
5. Press and release MUTE to install the code.
SOURCE: lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
SOURCE: need tv code number for 32"LCD Dynex Television for my universal
Ran a search and someone said Funai made it's codes are 0818, 0179, 0171
Someone else said it's made by Orion codes are 0236, 0179, 0463
You can try these codes hope they can help you.
SOURCE: remote control code for the MXT LCD TV
MXT 15.4 LCD 1561D 12V 60W No operation instructions can you help me please
SOURCE: i need the universal remote code for the mxt
Hi, I have a remote for an MXT LCD combo, my tv was stolen.
I have nikai tv without a remote control so where can i get the remote or unversal one here in Zambia and iam asking for the code it's a 42 inch tv
