Question about Kohler Electrical Supplies
We have a Kohler gen set M#300R0771,spec#116304A5-28,the generator starts but does not come up to speed,my question is what is causing this?We also need manuals for this machine.Decision Maker 2 cont.
Posted by Keith Kane on
BrianHaze
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 23 Answers
The parts manual is a tp-5317 which I do not have . You said its a dec2? or a fast response 2? What is the part number off the main circuit board in the control box?
Posted on Apr 16, 2019
5 Related Answers
rjivaro
  • 158 Answers
SOURCE: electrical wiring for kohler engine
Perhaps you would enjoy the entire service manual. Here it is: http://www.asberry.net/files/TP-2379.pdf
Posted on Apr 29, 2009
Anonymous
I have a Ford LGT with a 14 hp Kohler K321AS engine. Go to Kohler.com and download the service manual for the K321 engine. The manual covers all of the K type engines and gives diagrams and details of all the different types of ignition and electrical systems. It is free. JS
Posted on Jun 07, 2009
jamie
  • 1810 Answers
SOURCE: UU undervoltage kohler 20kva
call koler but ui think is meant high heat as in the thermal circut is shuting you down or low oil
could be a couple of things best bet call kohler
Posted on Aug 06, 2009
Fred Yearian
  • 5603 Answers
SOURCE: kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Posted on Aug 11, 2009
Wayne Holden
  • 512 Answers
SOURCE: What is the most likely cause of an Auxiliary Fault on a Kohler Generator (Model 30RZ62)?
Problem solved by poster. good work!
Posted on Oct 08, 2012
Why doesn't it start?
gen sets have to be run at set rpms so that the voltage and cycles are correct for the applications
with the rpms as little as 100 rpms below requirement , the voltage will be down , causing a brown out which burns out electric motors and if the rpms are low the required cycles will also be off which affects electronic equipment
service the gen set and find out why the rpms are not at the set level
Jan 09, 2016 | Generac Guardian Air-Cooled Standby...
How do you seperate a kohler motor from generator on a miller welder?
if by asking this im assuming the generator is face bolted to motor , if this is so , to save from having another front bearing , the gen stator is directed attached to motor shaft , on the far end under end bell cover is the end of shaft , a long bolt goes thru gen shaft to screw into motor shaft , MARK/photograph all the wires you unhook helps a lot when puting back together
Aug 05, 2014 | Kohler Replacement Engine Part Pa-64711...
GEN SET WILL NOT START /MAIN POWER OVERLOAD
I have a Generator Kohler Res14 and its not crancking, and error of invald shutdown
Jul 30, 2013 | Kohler 20resa 20kw Home Emergency Backup...
I have a Kohler 12.5 KW marine generator on my houseboat that has a problem I was hoping you could help me with. Specs: Kohler 12.5 KW 79 CID 23HP Mfg date 9-10-96 Gen Engine Serial # 06919 L-29-R
there are some magnets behind the flywheel to cause the battery charging system to recharge the batt. sometimes they come unbonded/loose from the flywheel and cause the engine to become hard to turn. I would start there first.
Apr 03, 2013 | Cars & Trucks
Kohler RXT won,t start Kohler 20resa
Did you check the remote terminals and relay in the ATS, disconnect gen remote wires, kill the ATS brealer and ohm across the start terminals, they should close, if not a relay/control board issue, if they do fault is in wiring or gen control, or incorrect wiring
Jan 03, 2013 | Kohler RXT-JFNC-0200A-QS 200 Amp...
I have a Kohler Confidant 5, model 5ckm21 generator in my RV, serial # 326827, spec# 101228. It worked fine one evening and the next day it wouldnt stay started unless the start button stays depresse
no 14vac coming from generator to control board.--cause can be regulator board on end of generator---dirty brushes or worn out brushes==b1 and b2 winding open that outputs the 14vac--my problem was blown regulator board
Dec 05, 2012 | Kohler Electrical Supplies
Kohler Model 12RES LP gas generator starts normally but immediately shuts down with over-voltage alarm. Control panel replaced.
Sounds like a short in one of the windings to me. Can you verify that the engine rpm is not exceeding specs? If you can modify the engine speed Id say slow it down and see what the voltage read is.
Jul 22, 2010 | Kohler 12 kW Emergency Power System -...
Engine speed & frequency specs
most gen sets are set at 3600 rpms at 60 hz
Oct 11, 2009 | Electrical Supplies
10 kw deisel generator in sailboat suddenly stopped generating,
Are you still looking for help with your Gen. ?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jan 30, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
Electrical Supplies Logo
190 people viewed this question
Top Kohler Electrical Supplies Experts
John Trevino
Tim Venetis
jdthefixer
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
