Question about HP OfficeJet D125xi InkJet Printer
All Lights Flashing
Claims to have too little power on another website. Power supply checked. Supplying 32.6 volts.Correct. Says to then service it. Cleaned out ink tray and pad which was full of ink and carriage, rod, rollers etc. Still flashing. It would appear to be a Power supply problem within the printer or a motherboard fault. Any suggestions would be appreciated. Stumped.
Posted by bdystems on
Anonymous
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 52 Answers
Your printer need service. Its firmware problem. All lights flashing error state usually indicates a hardware problem of your printer.
Posted on Aug 04, 2009
I have a HP Photosmart B8350. I haven't used it for about a few months. The green indicator light on the power module is on but the printer will not power up. Don't know what to do.
So the printer has no indicator lights on at the printer? If so have you verified the power supply is working and is supplying power to the printer. You need to check the voltage output with a DC volt meter.
Nov 24, 2016 | HP Office Equipment & Supplies
How can I check when the alternator is not supplying enough power to the battery,or when alternator drawing power from the battery I remove one terminal while the car idle it did n't die.I suspect
The alternator output must be more than 12 volts, usually +/- 14 volts. Measurements may be made with the engine running connected/unconnected to battery. Once the engine is running, disconnecting the battery will not normally cause the engine to die/stop. However, lights, radio, clock, and other accessories will not have power.
Oct 10, 2015 | Cars & Trucks
Captiva battery run down quikly
Sounds like the alternator is not supplying enough power, or the battery is old and not holding a charge. Connect a volt meter across the battery, start engine should read between 13.5 and 14,5 volts, turn on headlights and heater blower meter should hold around 13.2 volts, if it drops lower then the alternator is not supplying enough power. The alternator drive belt may be slack? If its the battery, you will need to get a workshop to check it.
Dec 30, 2013 | Chevrolet Cars & Trucks
The lights do not come on when plugged in
If you have a volt meater check the power supply to see if it is sending the correct power. If you get a rating more that 5 volts above or below the rated voltage you have a busted power supply. If it is above 5 volts the router is most likely dead.
If you don't have one try to locate another 12v (or whatever its voltage is) power supply.
Jun 13, 2011 | 2wire (2701HG-B) Wireless Router
MONITOR ONLY HAS FAINT IMAGE, COMPUTER WORKS WITH EXTERNAL MONITOR, HAVE REPLACED SCREEN TWICE AND INVERTER BOARD TWICE, NO LUCK--OTHER SUGGESTIONS?
When you have a faint image, it means that the backlights are not turning on, most of the time, its the inverter not supplying power to the lights.
My suggestion is to take a volt meter and test the voltage going to the inverter. I can not tell you what it should be, but you should have voltage more than 5 volts going to it. Its very possible that if you changed the inverter and the screen, that the main board is not supplying enough power.
thanks adi
Feb 21, 2010 | Toshiba Satellite M35X-S163 Notebook
Power to printer but printre will not turn on as there a reset
Are you using a volt/ohm meter to determine that the transformer is supplying power to the printer?
If so, what is the input (measured at the receptacle) to the transformer?
What is the output of the transformer and is it supplying the correct amount of voltage (output voltage requirement is normally found imprinted on the body of the transformer or in the technical specifications section of the printer's manual.
Don
Dec 01, 2009 | Canon i860 InkJet Photo Printer
Picture will not come on but sound does
It can be the backlight inverter board is bad or the power supply is not supplying power to the inverter board.
Nov 01, 2009 | Digital Lifestyle FA1B32Z 32 in. LCD...
Aternator warning lamp flashing with loss of
Try charging the battery overnight, start the engine and measure the battery voltage. It should read 13.5 to 14.5 volts DC. If it reads 12.6 volts, the alternator has quit supplying energy. Take the car to your favorite auto parts supply store and have them test the alternator right on the car. They usually do this for free as they hope to sell you a replacement part.
Sep 26, 2009 | 2004 Audi A4
NO Picture or Sound on my FLM 26-32
Either one of two problems, the main power supply has an issue or has gone bad. 'Not supplying the correct voltages to your processing/controlling board' or that you are having problems with your processing/controlling board. My guess is the main power supply board.
A Good TV Service Shop would give you an idea of what the cost of repair should be. Call around.
Blessing,
A/V Media Tech Guy
Jul 22, 2009 | Polaroid FLM-2632 Television
HP OfficeJet D125xi InkJet Printer Logo
120 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
