Question about Photography
I have over 500 photos on my frame but it seems the same ones keep coming up. How do I get more of a variety in the viewing?
Posted by Lorraine Kirkpatrick on
I have a Philips PhotoFrame - SPF3408/G7 (SPF3408T/G7). When plugged in no picture comes on screen. Screen does not light up. I viewed pictures yesterday - but - I don't get anything today. I know...
Keep in mind that Digital Photo Frame can display the same photo continuously for 1000 hours without any damage to the LCD screen.
If you can enter to the settitgn menu, first make sure the system is properly powered. Then use a pin to trigger the reset button located on the side of the power button on the back to restore the system...
If this isnt work try...
  1. Load all the photos you want to upload to the Photo Frame in the root directory of your memory card.
  2. Power off your Photo Frame by pressing the Power button.
  3. Insert the memory card into the slot in the frame.
    A For a Compact Flash card, firmly slide card in the larger slot end first and face down.
    B For an xD, SD, MMC, or Memory Stick card slide card in the smaller slot end first and face up until it locks into place.
  1. Restart Photo Frame by pressing the Power button.
  2. After a few seconds, all photos in the root directory of the memory card will be automatically added to Photo Frame. The root directory on memory card will not be emptied after this operation.
    Please do not remove the memory card just after inserting it in Photo Frame or when Photo Frame is counting the Photo.
    Wait until the screen is stable.
    NOTE: This operation does not apply to photos in sub-directories.
If anyone of this procedures work fine, I suggest contact your local service (check if even is underwarranty).
Good luck.
Jul 05, 2011 | Video Game Consoles & Games
How do i download photos from pc to digital photo frame
1. Connect the digital photo frame to an available USB port on the PC. Turn on the PC and the digital photo frame. Connect one end of the USB cable to the USB port on the digital photo frame (this end is usually smaller) and connect the other end to the USB port on the PC itself.
2. Wait for the PC to automatically detect the USB-connected digital photo frame.
3. Move any photo files that you want to display on the digital photo frame. Do so by copying and pasting each file into the connected USB device that you can view in "my computer". Many photo frames have built-in memory for this feature.
Jan 07, 2011 | Microsoft Computers & Internet
How much do a used engine cost?
Hey colin I need your help bigtime
I cant find a way to message you on here.I need to bypass the pats system on a ford focus...I took the case off the alarm
computer....I ran a hot wire to the fuel pump and the starter,how can I get spark
May 14, 2010 | 1994 Jaguar XJ6
How to get a photo to pause
View Individual Photo
1. On the photo thumbnail screen, use ? / ? to highlight a photo and then press ENTER to view it individually.
2. Press EXIT to return to the photo thumbnail screen
Mar 18, 2010 | PANDIGITAL 6.0-Inch Digital Picture Frame...
How do I keep a photo rotated?
Not all frames can save rotated images. Try rotating a photo on the frame's built-in memory, not one on a memory card. If it still does not save, then this model does not save rotated images.
Jan 01, 2010 | PANDIGITAL 8.0" Digital Photo Frame...
Need english manual for 512 mb 7" LCD
[PDF] 7Digital Photo Frame User Manual File Format: PDF/Adobe Acrobat - View as HTML
Digital Photo Frame. Please read carefully and follow all warnings and instructions in this User's ... Product: 7”LCD Screen Digital Photo Picture Frame ...
www.x-digitalmedia.com/PDFs/7inch.pdf - Similar pages
May 07, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
Quantaray 5.6 Digital Photo Frame not working properly
Maybe if you were to calm down and approach the situation calmly, you could figure it out. Or, or course, you could try looking in the manual - that often helps.
Mar 13, 2017 | Quantaray 7-Inch Digital Picture Frame -...
Transferring photos from computer to photo frame
I just called the company because I have one as well. They told me that in the case of my photo frame I cannot transfer them from a pc. I need to buy a usb storage device or other devices to keep the pictures. That needs to be on the photo frame to view pictures. I am not happy with this since they should have told us that it would cost more money. I will never buy Philips again!
Jan 03, 2009 | Kodak EasyShare EX1011 Digital Picture...
I bought a technika jp07 photo frame but when i put the sd card in it comes up no playable file. i tried the same sd card in another photo frame and it works fine. please help mrs bev bartram
It seems that it's not about the size of file or resolution of the photo!
I was given one of these yesterday. I copied my photos on to a 64mb SD card of unknown make. They display fine on my PC but on my Photo Frame I get the "no playable file" message. I tried changing file size etc but no good.
As a last resort I copied my same photos on to a 2GB SanDisk SD card and tried that. It works fine. So my guess is that these photo frames are picky on what SD card they'll accept.
A pity the manual doesn't tell you so!
Nov 13, 2008 | Cameras
Pentax K100D DSLR
The interface IC ( between the main CPU and the CCD sensor ) seems faulty . Camera should go to the Pentax agents unfortunately.
Sep 02, 2007 | Pentax K100D Digital Camera
Photography Logo
279 people viewed this question
Top Photography Experts
Marvin
Marvin
Tony Parsons
Tony Parsons
Are you a Photography Expert? Answer questions, earn points and help others
