SOURCE: MY EMERSON TV WILL NOT TURN ON...1 YR OLD?
Check and replace its main power regulator board as card basis. To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts.
SOURCE: what size screws do I u for Emerson #LF320Em4A to mount to stand
I too am looking for the screw size for a similair TV. Emerson was less than helpful when I called them with the question.
"quote" Since I can not find any info on screw size for the Emerson blc320em9 we think that the TV is not supposed to be wall mounted. "end quote".
This sparkling bit of wisdom was after I had already mentioned the the manual says it can be wall mounted.
Good Luck
SOURCE: I have a Emerson LED 32 LF320EM4A has sound no picture
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
SOURCE: Volume control on Emerson model lf320em4a returns to 0 when button is released
Be certain that (G) is not stuck in down position.
I use Contact Cleaner by WD40, but you may have a different favorite spray
