How to remove write protection from SD Card
Click on above link and watch the video. It will show you how to remove write protection.
Semper Fi,
Z
Semper Fi,
Z
SOURCE: turn off write protection on a sd micro card
In the menu, tools, memory card, options you should find the setting for memory card password on/off
If you are using it with the SD adaptor, the swith at the side marked lock is not to secure the micro sd card within the adaptor. This is the write protection. If you set this to the 'unlocked' position (up) then you should be able to write files onto it!
SOURCE: Can't un-protect Images in My Canon Rebel XS
It sounds like the locking switch on the side of the SD card is in the "locked" position. Remove the card from the camera and slide the tiny switch on the card to the unlocked position. That should do it.
SOURCE: write protection on memory card sd
try formatting memory card from your mobile then use it on computer
To retrieve deleted photos from memory card you need a good recovery tool and it must suit your needs .I would like to recommend this because it gives good results in SDXC cards .You can download it here
