Question about Clothing Accessories
What is best way to finish seams on knitted mittens and gloves
Posted by Joyce Humphrey on
L have finished knitting my sweater now i want to add a pocket at side seams how do i do it
Hi Marcel,
Un fortunately this is integrated in the actual knitting process. However, if you knit the pocket separately, you can then attach it to the garment by sewing it in using the wool you used for the original garment.
Hope this is useful.
Kind regards
David
Oct 09, 2017 | Sewing Machines
Want to make mittens with gumdrop stitch
Hi there, you may wish to join the knitting community on www.ravelry.com, its free and there are several lovely gumdrop mitten patterns there. Gumdrops pattern by Holli Yeoh
Sep 18, 2014 | Crafts & Hobbies
What are cut-resistant gloves?
Cut resistant gloves are gloves designed to protect hands from cuts while working with sharp tools. They can be divided into metal mesh gloves, cut and sewn and seamless knitted gloves.
Feb 06, 2013 | Clothing Accessories
What is the best way to store disposable gloves?
Disposable gloves should be stored in a shaded and dry place, with a low humidity level and a cool and dust free environment. You should avoid storing the gloves near direct sunlight, x-ray or extreme heat.
What are vinyl gloves?
Vinyl gloves are one of the different medical gloves. Vinyl gloves usually come unpowered or powdered with cornstarch in order to lubricate the gloves. Vinyl gloves are usually used as surgical gloves.
I am trying to get my singer futura ce-100 to be compatable with my windows vista home computer. i only need to do regular sewing with it. I want to be able to sew stretchy material.
If you are only sewing garments and in particular, knits why do you need your machine to be compatible with your PC? It should not be necessary unless you wanted to stitch out digitised machine embroidery patterns, something I've never done in 30 years of dressmaking.
To sew knits you need ball point needles, in an appropriate size for the fabric weight. Good guide to sewing machine needles is here - http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/
On knits you need either a very small zig zag stitch or your machine may have a stretch stitch where the fabric is moved forwards and backwards a little to put some stretch into the seam. Also use polyester thread. You need the ballpoint needle as it pushes between the fabric fibres rather than piercing them, imporant with knits to prevent the seam from popping/breaking when under stress.
For hems you can use a twin needle on the top of the fabric, this gives a nice finish to the seam and also some elasticity as the underneath bobbin thread forms into a zig zag to connect with the twin needle on top.
I would suggest that you visit the www.kwiksew.com website or this link
http://kwiksew.com/resources/articles/Ten_KWIK_Tips_Knits.pdf for lots of quick sewing tips for knits like attaching rib jersey for necklines and cuffs that speed up the sewing and give results similar to ready to wear. I bought their "Sewing for Toddlers" and "Sewing for Children" books and traced off patterns for PJ's, track pants and sweat tops and made loads of clothes for my boys from this one book, it is a great resource for knit sewing. They have other books too for adults.
Anything you need in terms of selecting stitches on your sewing machine should be in the instruction booklet, but how you use those stitches and assembly garments is best learnt from taking sewing classes or a good sewing book.
Other useful websites for sewers are www.sewing.about.com, www.patternreview.com www.burdastyle.com and www.sewingpatterns.com - there is also a yahoo user group called "FuturaEmbroidery" of fellow Singer Futura sewing machine owners that you may wish to join, often can pick up lots of helpful info and advise from fellow owners.
Jul 07, 2011 | Singer CE-100 Futura Computerized Sewing...
Clothing Accessories Logo
509 people viewed this question
Top Clothing Accessories Experts
Jim Pattison
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
