Computers & Internet Logo
A
Anonymous Posted on Nov 13, 2018
I have a LG Flatron E2750v Monitor connected with a standard cord between the monitor In the center of the screen it reads: D-Sub out of range 68.5Khz/85Hz VGA Port or Power saving mode HDMI Port
I have a LG Flatron E2750v Monitor connected with dist tv HDMI to monitor HDMI port but monitor show power saving mode & a standard cord between the monitor In the center of the screen it reads: D-Sub out of range 68.5Khz/85Hz VGA Port or Power saving mode HDMI Port
Jose Ma DM.
Level 3:
  • Master 540 Answers
  • Posted on Nov 14, 2018
Jose Ma DM.
Master
Level 3:
Answers
540
Questions
0
Helped
177091
Points
1776
Hi, that message indicates that your video source is providing an unsupported video resolution , please check in settings that video output resolution is no more than 1920 x 1080 @ 60Hz.
Also remember to verify that HDMI is selected as input source at monitor.
5 Related Answers
Anonymous
  • 24 Answers
  • Posted on Nov 21, 2007
SOURCE: LG Flatron monitor remains in Power Saving Mode
Sounds like an issue with a memory card or pci card not properly in place. Try opening up the sytem, then make sure each card is properly inputted in it's slot. This may cause the the monitor to show power saving mode especially if the memory is not properly placed.
Thanks
Anonymous
  • 16 Answers
  • Posted on Feb 06, 2008
SOURCE: My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Anonymous
  • 16 Answers
  • Posted on Feb 09, 2008
SOURCE: Analog Out Of range (LG Flatron L1750T)
some games need high resolution. Monitor resolution not supporting for this game.
Powersaver mode showing when the main PCB of the monitor failed. check this link to get the service center info
http://www.lgservice.com/
Anonymous
  • Posted on Sep 14, 2008
SOURCE: LG Flatron LCD Power Saving Mode
Hi, September 2008 and still problems happening with the LG screens. Mine is a Flatron W1942T.
I hit the screen as suggested (my old mum was a great believer in " if it won't work kick it", this applied to anything electrical, tele, vacuum cleaner etc.,) and guess what? my old mum was right. The screen came on.
Hope this works if it happens again. I'd turned everything off because of an electrical/thunder storm. Won't do that again.
Joan
Ekse
  • 13435 Answers
  • Posted on Sep 21, 2008
SOURCE: Power Saving Mode problem using the DVI input. VGA input Ok.
try the display on another computer, if the display does the same thing on another machine, then its definitely a problem in the display not in the computer drivers or bios.
I have a LG Flatron EW224 computer monitor. It was working great but one day the screen went blank and reads in the center of screen: D-Sub out of range 68.5Khz/85Hz. Does anyone know how to correct this...
This is usually due to your computer Video resolution being set to a setting out of the supported range of your monitor, Lowering the computer video resolution should solve this issue.
1helpful
Automatically power saving mode ...........................cpu start working..........monitor power saving mode
Hook a spare monitor to the computer, if the same symptoms occur the problem is the Video Graphics Card in the computer, but if the picture is okay, it is clearly the LG Flatron that has the problem, and if possible sub the video cord from the computer to the monitor just to be sure.
2helpful
Analog out of range display on the screen
try the lcd monitor on another PC, if the same message pops out, your monitor needs reprogramming of its A/D board, bring it to a LG service center..
if it works fine on another PC, try to boot your PC on VGA mode..
1helpful
2answers
I have upto now been using my LG Flatron L1919S monitor as a tv with a separate tuner. today i replaced it with an LCD tv and was going to use the monitor for my computer. however when i connected it up...
It means your PC video output resolution is too high for the LG monitor to display (your old monitor (CRT) can handle higher resolution than this LG LCD monitor), you need to set the PC video resolution to native resolutionof this monitor which is 1280 x 1024 @60Hz. You may have to use the old monitor (CRT) to set the resolution to 1280 x 1024@60Hz, then hook up the LCD monitor.
1helpful
I think I have connected the wrong plugs into my monitor, cpu and printer. What power cord does the monitor use ?
most monitors use the standard 3 pin connector just like desktop computers.
If it uses something different it will most likely be a 2 pin figure 8 shaped style or a single male connector that comes from a brick.
2helpful
I am using the LG Flatron L1715S 17" LCD Monitor as an external monitor for my lap top as the screen on my lap top is toast. What I cant figure out is how to size the screen to fit the proper dimensions of...
The FLATRON L1715S color LCD monitor with auto-synchronous support, plus it is PC and MAC compatible, has features like simple one button auto setup and is VESA DDC2B, DDC1, Plug and Play compatible.
use the 'Auto' adjust button on ur lcd..
howevr, if u want to configure using win xp/vista..right click on ur desktop->properties->settings->increase the 'screen resolution' to minimum: 640x350 or standard: 1152x864 or maximum: 1280x1024 @ 75Hz..
best is to seek professional advice of ur system admin/vendor....
LG Flatron L1710S Monitor stuck in Power Save Mode
Try wiggling the Cord on the backside of the monitor.. Not the Power Plug Cord, The Other Cord that attaches to the PC. Do this once the monitor turns off , grab ahold of the cord about 2 inches from the back of the monitor, then bend the cord to the right, keep bending from the right to the left a couple times to see if your screen comes back, if it does, than you have a Loose connection and this sometimes causes the Symptoms you are receiving.. Hope it helps.
2helpful
3answers
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
