Question about GPS
Audiobank AB-3608GR 7" Indash Touch Display Navigation Bluetooth DVD Centre.Navigation GPS screen only show a black screen.Did change the SD card with new IGO9 maps no respons.
All ather fanctions work exsept the GPS.
Posted by jacques on
5 Related Answers
Anonymous
SOURCE: Freeway indash DVD
u need to switch function screen to dvd screen. Button is on front of unit to scroll through screens.
Posted on Dec 22, 2008
Anonymous
  • 5 Answers
SOURCE: gps navigation screen is paralyzed--all other screens are working
hi did you install the software straight to your route 66 maxi using route 66 sync software ? if you did try downloading it to your computer then transfer it on to the memory card using a card reader
Posted on May 01, 2009
Anonymous
  • 13 Answers
SOURCE: The preloaded SD card for my Evesham GPS is bad. I need a new one
You can buy software on Ebay for uk Maps. Its a CD.Just copy the software onto an SD Card.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150362945965&ssPageName=STRK:MESELX:IT
Posted on Jul 31, 2009
Anonymous
SOURCE: GPS 439 IGO route 66 -Car GPS can not find navigation not working
my navigon gps series 2100 has a problem with calculating the route and showing the turn - by - turn list.
Posted on Aug 19, 2009
SOURCE: Hi I have installed a MEOS
Hi, well this sounds to me as though something has gone wrong when the softwares were installed? I would say that this was the problem, and it will not "Boot Up" because of this. Especially if it DID work OK before.many softwares install fine with NO error message indicated, but still will not work, the download may have been corrupted?
Anyway, you have little choice other than to do a Factory Reset of the unit, (If possible) and then, try to reload the origional software. get it all going again, then perhaps try doing the installation of those softwares that caused the problem?
I suggest that you use the manual, download one if you do not have a copy, follow the instructions how to factory reset, and recover from a bad upgrade.
I don't think the SD card has any bearing on the matter. I would doubt that the touch screen would have gone spontaneously faulty, it may have but? more likely as related it is a software Glitch, with the freshly loaded new software.
Posted on Apr 13, 2011
Avic s1
hello sir,
Portable Smart GPS Navigation comes with 3.5-inch Touch Panel Display, 2GB Flash Memory, Bluetooth Wireless Technology, and Scroll Wheel
  • 2GB Flash Memory contains the map data of entire US and Canada
  • Just unpack and use it � no PC connection is needed for startup
  • Future map data updates will be available by SD card � just load into the built-in SD card slot and the update will begin
  • Quickly set a destination by address, zip code, destination history, and more
  • Search for a gas station, restaurant or coffee shop using the POI Search � destinations are sorted into categories for short-cut searches, or use the touch screen to type in the name.
thanks for allowing us to help you
Dec 30, 2007 | Pioneer AVIC-S1 GPS Receiver
Installation instruction
what vehicle are you putting it in, as if it was meant to be in the vehicle the wiring would be there already , if not forget it to much work and not much chance of getting it working properly anyway
Jun 01, 2015 | Ouku Double 2 Din Indash 7-Inch 2002 03 04...
Ouku GPS/DVD Can't find navigation software
Make sure your SD Card is inserted in the GPS SD card slot properly. it is located behind the head of the unit( where you insert your DVDs) usually has red or orange tape over it. just remove it and reinstall it. Hope this helps.
Jan 23, 2014 | Crown Ouku 7 Touch Screen 2 Din Car Stereo...
Alpine SD navigation system VIE-X05 update loading file free download
ALPINE VIE-X05 SD NAVIGATION SOFTWARE file need. my sd card is dad's plzz solution for me.
Jan 04, 2014 | Alpine 7-inch Double-DIN GPS Navigation...
GPS says no application
Go into settings then guide settings. Tap the sd slot card so the radio can read it should work now
Jul 04, 2012 | Crown Ouku 7 Touch Screen 2 Din Car Stereo...
Gps navigation screen is paralyzed--all other screens are working
Jan 07, 2009 | Route 66 MAXI Car GPS Receiver
Freeway indash DVD
Dec 14, 2008 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
GPS Logo
201 people viewed this question
Top GPS Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a GPS Expert? Answer questions, earn points and help others
