Question about Amana Washing Machines
My amana model Ntw4605EWO wont fill with water,lights dont come on,just a motor running noise
Posted by Tony Dunham on
hooftey01
    Habit-Forming:
    New Friend:
  • 19 Answers
Sounds like the motor control relay had the contacts fused closed. This would most likely lock out the the other functions.
Posted on Nov 13, 2018
5 Related Answers
Anonymous
  • 249 Answers
SOURCE: motor noise
it could be something caught in motor empeller IE. a bit of glass, or motor could be faulty
Posted on Nov 28, 2007
farfield
Farley Redfield
  • 462 Answers
SOURCE: water from dispenser slows down while filling cup
If your water is slowing down the screen on the water valve may be stopped up or the filter (if it has one, when was it last changed?) or line feeding the refrigerator may be stopped up or the water valve its self may not be opening all the way and staying open.
To eliminate 3 of the external problems take the water line off the fridge and run some water into a pan and open and close water like at your kitchen sink and see if the water slows or speeds up noticeably while running into the pan. If so the problem is in the water line. While you have thew line off remove and inspect the water inlet valve screen and replace the hose washer (if so equipped) this brings your problem if you have not found it yet to the inside of the fridge. Usually on the corner of the door hinge the water line makes a turn up to the dispenser inspect it there and see if its twisted or kinked. Also there is a water resiviour inside the fridge look there for the same thing and possibley where food may have been forced agianst the line.
If you still dont find it by now I'D have to know what you did find and where.
If this helps you please rate me with as high a rating as you can and thank you for using fix ya.
Posted on Apr 20, 2009
Jordan Schmidt
  • 58 Answers
SOURCE: drum isn't spinning but motor is
check inner tub fastens, if they check ok, replace the transmission. note: you will need special tools to change this, if you have them great, if not, you would be better off calling a&e factory service for the repair, 18009059505.
Posted on Jun 25, 2009
thebensonsmi
SOURCE: Kitchen Aid dishwasher model KDC-18 is not filling with water
Under the machine is the water inlet valve. if you take off the front end of that you find a filter which fills up with rust, and you can clean it out. If that doesnt work, repairclinic.com will sell you a new valve for 32
Posted on Sep 06, 2009
Anonymous
  • 14 Answers
SOURCE: water runs but doesn't fill tub and wont spin if put on spin cycl
The drain hose must be higher than the tub of the washer so many times I get called to find the hose on the ground to the drain an this will not let the tub fill.
Posted on Jan 28, 2010
Amana diagram/Manual for NTW4605EWO
Sears Parts DIrect has the parts diagrams and the manual for the Amana NTW4605EW0 washing machine. The parts diagram is here: https://www.searspartsdirect.com/model-number/ntw4605ew0/1268/0153200.html . The manual can be found here: https://www.searspartsdirect.com/partsdirect/user-manuals/ntw4605ew0-amana-parts-manual . The direct link to download the Use & Care Manual is https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/1401262L.pdf .
I hope this helps.
Oct 21, 2018 | Amana Refrigerators
Manual for Amana washing machine C60223609. Model NTW4605EWO
Google (amana)(NTW4605EWO)(manual) without parens.
May 24, 2018 | Amana Washing Machines
Model NFW7200TW Washer wont fill with water
Are you sure you have both hot and cold water connected? Try turning the water valve on, if you don't have hot water make sure you choose cold cycle. That's the first place I'd start.
Dec 02, 2015 | Amana Washing Machines
How to fix amana w10240534c washer wont fill?
check your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. no fill If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
May 31, 2014 | Amana 3.2 cu. ft. Top-Load Washer
Amana lw8303 clothes washer will not run or drain
I had similar situation. and changed out the water pump on my washing machine. it works great now.
Aug 29, 2012 | Amana Washing Machines
Amana br22 freezer fan noisy
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 25, 2011 | Baumatic BR22 8A Bottom Freezer...
The refrigerator keeps making a loud buzzing noise. It is not the ice maker filling up with water. The noise runs for about 5-10 seconds every hour or so.
Sounds like your starting components are bad on the compressor. If the freezer section begins to loose temp then this is probably the case. They will try to start the compressor and then it will kick off on its overload. However this will usually occur every 10-15 mins when they are completely toasted. Your compressor may be starting up part of the time and not starting the rest. Either way you will probably need new starting components on the compressor. You could also check to make sure your condenser fan motor is running (in the back of the ref behind the access panel) because this could cause the compressor to overheat but usually wont cause a buzzing noise.
Hope this helps _MJ_
Feb 07, 2010 | Amana Refrigerators
Washing Machines Logo
142 people viewed this question
Top Amana Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
